Radio Installation
Old Feb 2, 2009 | 09:03 PM
jimferra's Avatar
jimferra is an unknown quantity at this point
Default Radio Installation
Hey ladies and gentlemen, a noob here, my question is im installing radio amp and speakers. Has ANYONE found a way to route the power wire for an amp, (which ill be putting in cargo area), right now i have the wire running were i dont want it, which is on the d/s where the hinge is inside the fender, there no chance of it getting cut, but i was hoping to get it thru the firewall, which seems imposible!!!!! its a 97 blazer 4dr. Any Help would be GREATLY appreciated!!!!! Thanks inadvance..
Old Feb 2, 2009 | 10:41 PM
Brian_L's Avatar
Brian_L is an unknown quantity at this point
Default RE: Radio Installation
You should already have a pretty decent sized whole/grommet in the firewall by the drivers side for all the wiring going into the dash. If its not big enough have fun drilling through it! Haha its tough.
Old Feb 3, 2009 | 07:09 PM
mrafindley's Avatar
mrafindley is an unknown quantity at this point
This is a sore subject I got slammed the other day for asking the same question...They should really make this a sticky anyway on the passenger side pull the carpet a little bit and you will see where the ant. cable goes through use that hole shove the wire thru about a ft and look under the hood and there you go. I have the ant. wire a 8ga. wire and a 00 cable running thru that one hole and just changed the grommet
Boiler20
Oct 19, 2013 03:53 PM
dan_t
Nov 25, 2010 08:35 PM
iamchevyman5
Nov 7, 2010 01:20 AM
black19
Jun 22, 2006 03:35 PM
