Radio stopped working - 01 TB
Old Aug 15, 2008 | 06:03 PM
89LX's Avatar
89LX is an unknown quantity at this point
Default Radio stopped working - 01 TB
I have a 2001 Trailblazer with the regular radio system, not the bose. Today, the radio just stopped working. I bought another working radio from a junkyard, and that one didn't work. With my original radio in, the fan on the back doesn't spin, but the eject button works. Nothing lights up, and nothing plays. If I click the OnStar button, it plays and I can control the volume via the radio with no problem - just nothing lighting up, am/fm, or cd usage. I don't wanna upgrade, as this is just a spare vehicle for me, but I dunno what the problem is. If anyone has any ideas, please let me know where to look or where to start.
Old Aug 16, 2008 | 02:09 PM
bobditts's Avatar
bobditts is an unknown quantity at this point
Default RE: Radio stopped working - 01 TB
have you checked your fuses? have you checked the wiring to see if anything is corroded or has been cut somehow?
Old Aug 16, 2008 | 05:42 PM
Numba1Sean's Avatar
Numba1Sean is an unknown quantity at this point
yea do what bob said check fuses and for loose connections, corrosion, and fried wires.
Old Aug 16, 2008 | 08:06 PM
89LX's Avatar
Fuse was the first thing that was checked, but its getting the 12v constant on the orange wire because the CD eject is working, andI checked the voltage on it. The person that had it before me had a system in it, but all they had was the 2 audio wires and a green wire tapped into. I am assuming that the 2 audio are not causing it, but what does the green wire do?
Also, which other wires control the radio system to power it up? Which wire is the 12v ignition switched wire?
Old Aug 16, 2008 | 11:53 PM
Numba1Sean's Avatar
as i think that is normal wiring. the 12 volt switched would be yellow. green i would figure is a speaker wire, but i can't be quoted on that. so hopefully someone with knowledge of a trailblazer can help.
jstutzman
Dec 19, 2009 03:27 PM
acedrr03
TrailBlazer GMT360/GMT370 (2002-2009) Tech
Jan 17, 2008 10:37 AM
CamaroManBlack
Dec 8, 2007 12:10 PM
mac6135
Dec 8, 2007 09:18 AM
Stablock
Apr 20, 2007 04:29 AM
