is replacing a blown speaker that hard?
Old Feb 1, 2008 | 02:32 AM
jlee420's Avatar
jlee420 is an unknown quantity at this point
Default is replacing a blown speaker that hard?
the other day i blew the driver side panel speaker on my 2000 blazer i cant see it being that hard to repair. it would deff save me a lot of money to repair it my self so any help would be appreciated.
Old Feb 1, 2008 | 02:34 AM
jlee420's Avatar
Default RE: is replacing a blown speaker that hard?
so i forgot to put this in if you know size of the speaker i would need please add that
Old Feb 1, 2008 | 03:30 AM
Chevy Lover's Avatar
I don't know the size of speaker.
To replace the speaker : remove the doortrim panel.
: Remove the speaker retaining rivets.
: Remove the front side door speaker.
: Disconnect the electrical connector.
Reverse the procedure for installation. You can either install new rivets to secure the speaker or use screws.
Old Feb 1, 2008 | 06:09 AM
felonyblazer96's Avatar
felonyblazer96 is an unknown quantity at this point
it is most likely a 6.5 inch speaker...i believe there the same in the front and back
[/align]
Old Feb 1, 2008 | 06:52 AM
hillbillyinOhio's Avatar
2 door or 4 dr? sounds like you are asking about the rear speaker.
Old Feb 1, 2008 | 07:10 AM
01BlazerLT's Avatar
01BlazerLT is an unknown quantity at this point
The answer to this question is No. It is very simple to replace the speakers, I have done this on both the Blazer's I have owned a 4dr and a 2dr. If you have a 2dr you have 6.5's in the doors and 6x9's in the back. If you have a 4dr you have 6.5's in all doors.
The trick to getting to the speaker is knowing where the screws in the door panel are.
In the front doors you have 3, one behind the door handle and the other two under the door handle grab. You will need to remove the trim piece around the door handle after you remove the screw.
The rear doors have the same screw behind the door handle and the same procedure for the trim piece. Then there is a cover in the basin of the door grab that you have to remove and I believe their are 2 screws under this cover.
After screws have been removed the rest of the door panel is held on by plastic retainers. You will need something to get between the door panel and the door to pry the panel off.
Hope this helps.
Old Feb 1, 2008 | 07:52 AM
davtak's Avatar
Go to the auto parts store and look for a door trim removal tool. Not expensive at all. Just slide a cotton towel (I used an ordinary household washcloth) in between the door and the panel and get the removal tool in there to avoid scratching the door. Make sure you get the tool in right where the retainers are and they will pull the retainers out without breaking them. Don't put your hand back there and pull. The back lip of the door panel is a little sharp and I sliced my hand on it (ouch)! You can buy new retainers at the auto parts store too. They are cheap too. And yes, there are two screws under the cover in the back handle grab.
Old Feb 1, 2008 | 03:11 PM
jlee420's Avatar
wow thanks for the speedy advise ill try this once once i get some time my blazer has gotten the least amount of atteion lattley with working all the and goin to school once i get a chance to do this ill post the results on here
limited edition 1
Jan 27, 2023 11:07 AM
c3478493
Feb 3, 2014 02:56 PM
88s10Blazer
Jan 3, 2010 02:20 PM
SmokeU
Dec 20, 2007 08:14 PM
getonerd
Oct 30, 2007 12:33 AM
