Something Happened
Old Feb 4, 2008 | 10:23 AM
SmokeU's Avatar
SmokeU is an unknown quantity at this point
Default Something Happened
so i was driving along listening to some Finger Elevennot even loudand then my subs starts like making gurgaling and poping noices for no reason it will just go like POP bummmm POP POP bummmm
and then this morning while i wasent drining i could here that i believe my amp is turning on and off because when i turn it offwhen it was workingit makes a little click
so Im thniking that its not the subs but the amp or possibly the car battery connection
takeing it in to the installer in a while to get some iPod cable installed because he didint have any last time and i"ll have him look at itto
Old Feb 4, 2008 | 02:56 PM
NoPh33rRaCiNg's Avatar
NoPh33rRaCiNg is an unknown quantity at this point
Default RE: Something Happened
check the amps ground
Old Feb 5, 2008 | 02:10 AM
thegr81's Avatar
Check all the wiring and connections to see if any came loose!! Also let us know what the installer says about it!!
Old Feb 5, 2008 | 05:32 PM
chriswf's Avatar
chriswf is an unknown quantity at this point
Hmm. When I had an infinity subs with an infinity amp I used a trunk latch bolt as my ground once... If I had my gain up kinda high and it was a certain song playing it would do this sometimes. Moving the ground and shortening it fixed my issue.
I went to home depot and got a bit for my drill that had all these wire bristles coming off of it... I grinded the bottom of my trunk under the carpet and drilled a hole in the center... Bolted my ground there and I use it now for my kicker amp.
Old Feb 5, 2008 | 09:42 PM
Jharper's Avatar
Jharper is infamous around these partsJharper is infamous around these parts
mine is grounded to the rear seat bolt that holds the seat down. never had any ground problems.
massbasshunter
Oct 14, 2009 03:34 PM
TheDesertFox
Jan 2, 2007 06:40 PM
2dr5spdblazer
Sep 29, 2006 11:15 AM
Blazenfast
Aug 20, 2006 10:16 PM
blazergirl15
Jul 9, 2005 03:26 AM
