static
Old Aug 20, 2006 | 04:08 PM
blazinloud's Avatar
Default static
Ever since I had my heater core changed($800cad.) ive been getting static in my speakers, usually while switching the 'loud' setting or detaching the faceplate. It also happens while on pause and i hit a bump. I assume he just tugged on the wires while my entire dash was on my front seat(white sheep skin seats which now have black marks [:@] )
also on the wire subject, the wires by the gas peddle now stick out and catch my foot [&o]
Old Aug 20, 2006 | 04:51 PM
Jersey Autotronics's Avatar
Jersey Autotronics is an unknown quantity at this point
Default RE: static
first thing first u shouldn't have any wire by your gas pedal that not safe at all as far as static make sure you have a good ground on radio i don't know if your tech had to remove your headunit to replace core just double check!
Old Aug 20, 2006 | 06:00 PM
XBlazer01's Avatar
XBlazer01 has a spectacular aura aboutXBlazer01 has a spectacular aura about
Default RE: static
Pull the HU out and make sure none of the speaker wires are dipping down by the AC control and all that. Make sure they arent like right next to a major power line.
My neon likes were running by my stereo lines and i got hardcore static on ALL of my speakers. Just check em and seperate them from each other
U really gotta move that line down by ur gas. thats really not good. if it gets snagged and u cant hit the brake in time. yikes new front end.
Old Aug 20, 2006 | 06:10 PM
jagblazer01's Avatar
Default RE: static
id def. say to check your grounds first. I had this problem with my subs and come to find out that my RCA wire got pinched so I replaced that and no more problem
myloblzr
Lowering Tech
Mar 31, 2011 02:58 PM
cbr995
Aug 15, 2010 09:05 PM
sevendust4774
Lowering Tech
Apr 17, 2010 08:35 PM
JLaw
Suspension Tech
Mar 26, 2007 05:09 PM
Daytona
Mar 25, 2007 02:46 PM
