Sub and amp combo
Old Jul 10, 2008 | 12:30 AM
Spartan66's Avatar
Spartan66 is an unknown quantity at this point
Default RE: Sub and amp combo
ok thanks guys i will see if i cant get everything to swing my way with this equipment. Two final questions. 1. Would i need a specific size wire/wire kit to install this? 2. This sounds like alot of power, would I need to get like a bigger alternator or something along those lines?
Old Jul 10, 2008 | 01:37 AM
Good_Chevy's Avatar
Good_Chevy is an unknown quantity at this point
No, you should be ok. If your pushing more then 800 watts, it's a good idea to get a cap especially if your lights dim as you turn up the volume. Consult a professional about how to properly install/charge a cap if you plan on getting one. And be sure to get the proper gauge wire. If you get a brand new amp, the manual should have a diagram on what gauge for what wattage to use. If not then check this site out. http://www.cardiscountstereos.com/WireGuide.asp Good luck and if you don't know, ask, because there are alot of mistakes that you can make in car audio.
Old Jul 10, 2008 | 06:41 AM
bobditts's Avatar
bobditts is an unknown quantity at this point
caps are a bandaid for a bullet wound. If you know anything about electronics and do the math, you will see that in most cases, a cap is actually hurting your charging system more than it is helping. If your headlights are dimming and you add a cap, that places more of a strain on your battery which in turn strains your alternator even more.
If you never plan on adding another amp to your truck, just get a high quality 8ga wire kit. If you do plan on adding another amp to your truck, a high quality 4ga kit will work. Id recommend a kit from JL, knuconcepts, scosche, or kicker. Do NOT get your kit from walmart. Those wiring kits are actually smaller than what they really say they are.
Old Jul 10, 2008 | 09:21 AM
2drblazer's Avatar
2drblazer is an unknown quantity at this point
i just put a 200 watt vr3 amp a 10 inch jensen sub and a explode deck im my 99 2 dr blazer and it sounds great!
I didnt want any rattle, but i did want to hear the bass in my music and thats what i got. i spent no more that 100 bucks for my whole system i bought the amp thats was used for 2 days for 40$ the sub and box for 30 and the deck was free i had the wiring. The other interior speakers are stock but that is a little more of a project.
Old Jul 10, 2008 | 02:05 PM
Spartan66's Avatar
Yeah, i went the cheap route in my camaro and it was loud boomy annoying even at a moderate volume. I had a JBL12in,JBL amp and a pioneer deck with a rockford fosgate 8awg wiring kit. Im looking for better sound quality this go around.
talon2g
Feb 10, 2014 02:47 PM
88s10Blazer
Jan 21, 2010 07:05 PM
ABN31B
Jan 6, 2010 11:54 AM
$CR33D$
Tires and Wheels
18
Jun 2, 2009 11:30 PM
gstrat323
Tires and Wheels
Dec 12, 2008 11:09 AM
