SUB BOX PROBLEM
Old Nov 25, 2007 | 10:32 PM
felonyblazer96's Avatar
Banned
felonyblazer96 is an unknown quantity at this point
Default SUB BOX PROBLEM
i got a pair of jl audio w1 subs and the ported box their in is messed up. on each sub 1 screw will not go in even if u turn it the wood behind it is gone so when the subs hit air gets through cause no screw any suggestions besides bying a new box
[/align]
Old Nov 25, 2007 | 11:52 PM
cloak01ls's Avatar
cloak01ls is an unknown quantity at this point
Default RE: SUB BOX PROBLEM
Sounds to me that your box was poorly built. Glue should be the ultimate bonding medium and not the screw...If its not something that cant be fixed with wood glue then I would recommend building a new enclosure...
If its a prefabricated box toss it in the nearest dumpster and build yourself a good one...
Old Nov 26, 2007 | 03:33 AM
bobditts's Avatar
bobditts is an unknown quantity at this point
I wouldnt be so concerned with a tiny leaky spot. It is a ported enclosure after all. It isnt going to make a huge difference. If it still bugs you, build a better enclosure.
Old Nov 26, 2007 | 07:09 AM
getonerd's Avatar
getonerd is an unknown quantity at this point
what type of wood did they used
Old Nov 26, 2007 | 07:32 AM
jagblazer01's Avatar
just fill the hole with some wood filler, let it dry, and screw in ur sub.....or like other said, dont worry about it.
dimmuborgir6nik6
Apr 4, 2008 06:23 AM
rick465
Aug 25, 2006 09:37 PM
RdizzLe
Jul 19, 2006 12:33 PM
jagblazer01
Mar 15, 2006 07:58 PM
2001blazer
Jan 10, 2006 02:37 AM
