Sub Questions
Old Jan 5, 2008 | 06:13 PM
  #21
Zasder's Avatar
Zasder is an unknown quantity at this point
Default RE: Sub Questions
ok thanks!
Youhave any pictures of a finished box?
Also how would I go about putting on carpet? glue again...?
that picture is perfect! I was trying to figure out how I round off the other corner but this picture doesnt show it rounded! Very nice!
Old Jan 5, 2008 | 06:24 PM
  #22
cloak01ls's Avatar
cloak01ls is an unknown quantity at this point
ORIGINAL: Zasder
ok thanks!
Use spray glue for carpet.
I dont ahve any pictures but i could try to snap acouple of the one I did last night. Thats going to be almost identical to what you should have...If the rain lets up a tad i'll go out there...
Old Jan 5, 2008 | 06:30 PM
  #23
Zasder's Avatar
Sorry one more question well two
Should I drill out the speaker hole before putting the box together?
and... Does it matter where it lays in the there? or should it be centered?
and again thanks so much!
oops 1 more... for the wiring of the sub, should another hole be made? or can the wires come out of the port...?
Old Jan 5, 2008 | 07:29 PM
  #24
cloak01ls's Avatar
its a lot easier to make the sub hole after the box is together because you have bracing and dead space underneath for your jigsaw. It doesnt have to be centered with this design, it can go basically anywhere, but centered will probably look better.
Wires coming out the port is a bad idea. Not only does it look like crap but it can add to the turbulance factor resulting in noise. Just drill a hole in the back of the box wide enough for your wire to pass through. Then use hot glur or cilcone on the inside to seal the hole air tight...
p.s. I just snapped some shots of the box I built yesterday so ill post a thread here in a few minutes so you can see...
Old Jan 5, 2008 | 07:43 PM
  #25
Zasder's Avatar
Excellent! I gotta stop asking questions and just go at it! haha
Monday I will be starting the process!
cant wait to see the finished project...
Old Jan 5, 2008 | 07:45 PM
  #26
cloak01ls's Avatar
Ask all the questions you need to man, thats what im here for...
Old Jan 7, 2008 | 12:10 PM
  #27
Zasder's Avatar
Well I went to lowes and I got all the mterials!
Problem is lowes is retarded! I gave them all the specs of how I want the wood to be cut and they say we cant promise the cuts!
All the wood cuts are off...
and when I tried to fix the problem at home I made it worse
And I dont have the money for a real saw! Grrr
Old Jan 7, 2008 | 12:34 PM
  #28
cloak01ls's Avatar
I told you you have to babysit them. Bring your own measuring tape and mark off the cuts yourself. Be a dick about it. When my table saw broke i went to Lowes and had them cut it for me. They made one cut an 1/8th off and i made them cut me a new sheet...Its not hard at all to make perfect cuts with that $2000 saw they have...
Old Jan 7, 2008 | 12:44 PM
  #29
Zasder's Avatar
I am going to go to home depot and mark where I need it cut!
My goodness how can they be so far off? How do they still have a job there?
Old Jan 7, 2008 | 02:25 PM
  #30
cloak01ls's Avatar
remember to compensate for the 1/8" blade width...
