subwoofer box build
Hello all this is my first post and well I just finished this project last weekend so I thought I'd show you all my box build. I wanted something that wasn't going to take up a lot of space because I want to be able to use the space in my jimmy for other things. so I bought a 10w3v3-2 and a a1200 JL amp. the box is 14x18x8.5 on the bottom and 10 on the left hand side with a 124 degree angle cut I spent a lot of my time cutting various pieces to make sure all my measurements were right along with the angles the bottom cut (8.5) is 124 degrees so I cut a 28 degree cut and the top end was a 17 degree angle cut. the way you figure out the angle cut is take what the angle is ex:124 divide by 2 the minus 90 and that will give you 28 once I found that info away I went. anyways here are the images of the box being built and installed
CLICK TO ENLARGE
CLICK TO ENLARGE
I wish my interior came out easily....(gotta finish dynamating)
The box is cool tho, I am in the hunt to find a better way to run my wiring through the box, and the ideas i find help a ton....
whats the coating on the enclosure?
its hurculiner my jimmy is line-x inside and out (all the panels were removed, line-x is a great sound deadener btw ) but to have things line-x is exspensive and a can of hurculiner goes a long ways. If you use hurculiner though and you want to save the roller that came with it put the roller in a small ziplock bag and then fill it half way or a lil more with acetone and the roller wont dry with the hurculiner on it.
Other than that can't think of too much.
Do you mean the speaker wire running inside the box or the speaker wire going from the amp to the box. I've seen some people run bolts through the wall of the box, and use ring terminalson each side to run wire to the wire terminals on the subs. Best thing about this is if you have multiple subs, you can change the ohm load on the amp without pulling the subs out of the box. Just swith the wires on the bolts.
