system install.
Old 03-17-2007, 02:36 AM
03blazer's Avatar
03blazer is an unknown quantity at this point
Default system install.
How Hard is it to hook subs up to a stock radio? Where do i connect the rca's and the blue amp wire to? thanx for the help. ive never hooked up subs to a stock radio and need some advice.
Old 03-17-2007, 09:16 AM
hillbillyinOhio's Avatar
Default RE: system install.
You either get a amp that has hilevel inputs (speaker level) where you can just run wires to the rear speakers for the signal, or you get a Line Output convertor, which you hook up to the rear speakers and it converts from speaker level to rca inputs. and for the remote wire, you attach to the Yellow wire behind the factory radio. That is your Switched 12 v line..
http://www.sjgreatdeals.com/sisloc80.html
Old 03-17-2007, 04:19 PM
03blazer's Avatar
Thanx!
shaby
09-22-2013 11:40 AM
Läyskä
04-28-2012 06:22 PM
glamisfanatic
01-16-2012 02:07 AM
mx_579
09-16-2009 04:48 PM
thatyoungin
12-05-2006 01:53 AM
Quick Reply: system install.
