Toggling an Neon Light
Old Mar 7, 2009 | 08:11 PM
Soco_Live's Avatar
Soco_Live is on a distinguished road
Default Toggling an Neon Light
Hi there. I have a 89 Blazer that I want to run these two LED Neon Lights with. Currently I use the cigarette lighter but I hate the bulkingness of it. I would love to somehow wire these two up to a toggle switch but I'm sligjtly mechanically inclined. LOL Can someone please possibly explain to me how this can be done if at all? Any suggestions will be very much appreciated. Thanks.
- Sarah
Old Mar 8, 2009 | 12:15 AM
bobditts's Avatar
bobditts is an unknown quantity at this point
so I guess there is no option to post pictures anymore? hmmm. well here is the link
http://www.the12volt.com/12voltimages/addremacc.gif
Old Mar 9, 2009 | 03:34 PM
my's Avatar
my
my is an unknown quantity at this point
ok it is esay you are ging to have to fin out which wire is negive and positive the negitive is goung to have to be srewed to a meatel the floor the fire wall ect. then you are going to tacke and run the other wire to the place whare you are going to put switch you are going to have to spice a wire clip on the end of the wire and that clip should go on to the back of the togel switch on the switch ther are most of the time three prongs one is an acc. if you wont the light on the switch to work than you have to run a nother ground from that prong to a ground than thare are the other two pick one to run the led wire to the last prong youare going to run a wire from it whith the same kind of clip and it is going to go down to the junction bocks down by your brack pedil it should have an open prong just pick one they all have a constan power goning to them so if you do not remeber to turn off the lights you are going to get a dead battery this is the sempelest way to do it if you do not undestand some thing just let me know heer or at cemerson@sad5.org
Old Mar 9, 2009 | 03:39 PM
my's Avatar
my
hay if you give me your email i can sent you a better diagram to go by it could make it esayer
97CountryJukeboxLt
Feb 3, 2011 07:03 PM
blazerboy001
Jun 11, 2010 07:39 PM
getonerd
Nov 26, 2007 09:17 AM
jagblazer01
Jun 8, 2006 10:29 AM
jagblazer01
Feb 25, 2006 07:03 PM
