tuning your amplifier just right.
Old Feb 21, 2007 | 06:16 PM
RCarp48's Avatar
RCarp48 is an unknown quantity at this point
Default tuning your amplifier just right.
What should I set my frequency levels to? and any other stuff i need to adjust?
Old Feb 21, 2007 | 06:23 PM
drperry's Avatar
Default RE: tuning your amplifier just right.
Depends on the amp/speakers/subs...
For most subs, setting your x-over from 70 - 90 Hz will do ya great, whereas for most other speakers, you want to cut out anything lower than 120 or so... I just flicked the switch on my 4 channel to "HPF" lol
Old Feb 21, 2007 | 07:29 PM
RCarp48's Avatar
Say I have 2 lanzar 12's, dual voice coil, 1000 watts peak each, 500 RMS, with a 975 peak power rockford fosgate amplifier? Does 80 Hz sound about right? and sometimes when I am playing them loud they'll cut out and come back on in about 2-3 seconds, is this bad or some kind of warning or somethin?
Old Feb 21, 2007 | 07:43 PM
drperry's Avatar
80Hz should work good
And yes, the cut out is bad... watch your amp, and see if it's going into protect mode.
Old Feb 21, 2007 | 07:55 PM
RCarp48's Avatar
and if it is?
Also, Is there a certain way to place your subwoofers. Say point them in a certain direction in your trunk to maybe gain a couple db's?
Old Feb 21, 2007 | 07:59 PM
hillbillyinOhio's Avatar
THen you either have the gain set up too high, or you have subs wired wrong, or you have a ground issue.
and for other question
HERE
Old Feb 21, 2007 | 09:46 PM
RCarp48's Avatar
Do my subs going into protect mode prevent them from blowing or no?
Old Feb 21, 2007 | 10:19 PM
PLEASE DO NOT CREATE SAME POST IN DIFFERENT THREADS!!!
Yes, in theory, amp going into protect will help save your subs, but it wil kill your amp after a while. You need to fix the problem. I gave you possible reasons for your amp going into protect above, check those things out before anything else, including figuring out which way to have your subs firing.
altoncustomtech
Jan 5, 2012 07:40 PM
ExplicitYourSelf
Aug 20, 2010 04:11 PM
jacobc89
Jan 7, 2010 06:52 PM
Ken_C
Oct 16, 2008 01:26 PM
RCarp48
Apr 30, 2007 12:59 PM
