tweeter interference
I need help with this head scratcher, please. Its driving me crazy.I just replaced the stock tweeters and mids in my 95 Blazer with some Lanzar's Heritage series(dash and doors only). The power wire and amp turn on are running down the driver's side. The RCA's and speaker wire are running down the passenger side.In the driver's side tweeter there is a distortion that Ican't getrid of. It doesn't matter whatlevel thevolume is at. The distortion is onlypresent in theleft speaker. The right side is clear as a bell. My biggest concern is where the power wire comes through the firewall and the left speaker wires cross. They don't run along side each other, only cross perpendicular. Could this be enough to cause an interference?? What can I do to fix this?? In order to enjoy my tunes(cleanly & clearly) I have to crank the balance all the way to the right. Please help. Thank you in advance for your help. Much appreciated.
ORIGINAL: bobditts
speaker wires do not pick up ANY audible noise from power wires. There is either a problem with the tweeter or your install. Make sure none of the wires are grounding out anywhere.
Do you think that the tweeter is blown? Should I replace the wire with a high quality shielded one?
Well, finally took a closer look at the wiring. I inspected every inchand they turned up alright, no cuts or scrapes or anything of that nature. I did discover though that the amp channel that was powering those speakers is shot. So now, I am looking into repair as opposed to replace.
Has anyone had repair work performed on their amps before?? Is it worththe time and effort?
tjmicsak
Jul 9, 2011 10:57 AM
skybum02
Apr 15, 2008 01:33 AM
95, amp, blazer, front, inerferance, interference, interferences, pick, problem, running, speaker, stock, tweeter, tweeters, wirers
