Vss?
So I replaced my stock speedo with an autometer guage. My quesiton is, what should I do with the VSS that was attached to the rear of the stock speedo?
Here are a couple pics.
here is the actual piece (sensor?) that was attached to the back of the stock speedo
here is the control box that the sensor is connected to.
well that is what Im asking. I dont know exactly what this thing does. I assume it was important since the stock speedo had it. If it wont screw with anything (the computer) if I remove it, then why did the factory even put it there?
That is why I just said to tie it up. Maybe seal up the end with something, but leave it in. The end that you have in your hand in the pictures only went to the speedo. But I do not know what the box does in addition to that.
You could always unplug it and see what happens.
svd85
Nov 28, 2009 09:10 AM
Blindthieves
Feb 4, 2008 05:24 AM
