Vss?
Old Oct 13, 2009 | 09:49 PM
bobditts's Avatar
bobditts is an unknown quantity at this point
Default Vss?
So I replaced my stock speedo with an autometer guage. My quesiton is, what should I do with the VSS that was attached to the rear of the stock speedo?
Here are a couple pics.
here is the actual piece (sensor?) that was attached to the back of the stock speedo
here is the control box that the sensor is connected to.
Old Oct 15, 2009 | 11:01 PM
bobditts's Avatar
anyone?
Old Oct 16, 2009 | 10:21 PM
bobditts's Avatar
no love swartlkk?
Old Oct 17, 2009 | 07:50 AM
Wrap it up and stick it under the dash... That really isn't the VSS. The VSS is what is in the trans. That would just be what drives the stock speedo.
Old Oct 17, 2009 | 08:12 AM
bobditts's Avatar
what do you mean "drives the speedo"? Can I just un plug the lights from the light blue box?
Old Oct 17, 2009 | 08:17 AM
What do you need to do with it? That is the question. Do you just want it out of the way?
Sure you could unplug and remove the blue box if you do not need anything from it.
Old Oct 17, 2009 | 08:39 AM
bobditts's Avatar
well that is what Im asking. I dont know exactly what this thing does. I assume it was important since the stock speedo had it. If it wont screw with anything (the computer) if I remove it, then why did the factory even put it there?
Old Oct 17, 2009 | 12:03 PM
That is why I just said to tie it up. Maybe seal up the end with something, but leave it in. The end that you have in your hand in the pictures only went to the speedo. But I do not know what the box does in addition to that.
You could always unplug it and see what happens.
svd85
Nov 28, 2009 09:10 AM
Blindthieves
Feb 4, 2008 05:24 AM
19BLAZER96
Dec 31, 2007 03:13 PM
wolv2401
Jan 6, 2007 04:26 AM
2klt
Feb 27, 2006 11:15 PM
