Wet Wires going to Amp... Need help!!
My passenger side floorboard is damp and wet. I have no idea where the water is comming from. I have wires for my amplifier going under the carpet on my passenger side floorboard. I am afraid the wires will get damaged. How do I fix this?? Is there anyway to waterproof the wires?? Or put on a waterproof sleeve or something?? I checked underneath the car. The wetness goes right through the floorboard. Its not that bad, but can hurt my wiring and corrode them. Any ideas??
Yes, the wires are insulated. But, everytime it rains the floorboard will get damp and wet again. No garage. Could I install the wiring on the driver's side instead of the passenger side?? I will see if I can put the wires by the driveshaft tunnel under the console. How about some waterproof tape and just wrap that around the wires. Would that help? Thanks.
I found the problem when installing the Amp and sub. A rubber grommet about 2 inches or so big, was missing out of the firewall. Must have been removed when Uninstalling previous system. But, Problem fixed. Should be no more issues with water now. So, I was able to run the wires to Amp on passenger side A-OK. Thanks.
maxvamp
Oct 31, 2020 08:19 AM
JohnBarJB
Sep 28, 2020 07:34 PM
bmx4life218
Aug 3, 2010 01:32 AM
rogggg1020
Sep 24, 2008 06:53 AM
