where did you place youe grounds for your big three upgrade
Old 10-13-2009 | 10:18 AM
old skool luvr's Avatar
put a ground on the lower front passenger side of the block itself, like mentioned before, there are already holes drilled & tapped there. and put one on the back of the driver's cylinder head, this can go to the firewall. again, there is a hole already drilled & tapped there for this purpose (it's also used for the bracket set-up if it was on the passenger side cylinders). these two spot should be adequate. you can also add one to the driver's side lower bell housing bolt, and run it to the frame rail beside it. just make sure it doesn't interfere with the exhaust routing.
brown_eye
02-16-2020 06:30 AM
chris015
02-24-2012 03:44 PM
ExplicitYourSelf
08-20-2010 04:11 PM
NVANZEE
03-20-2009 05:43 PM
riceh8r0512
06-08-2008 08:12 AM
Quick Reply: where did you place youe grounds for your big three upgrade
