Where to go through the firewall?
Old Apr 25, 2007 | 02:58 PM
Kaffeene's Avatar
Kaffeene is an unknown quantity at this point
Default Where to go through the firewall?
Anyone know of any places to get through the firewall?
I've got to bring a 10awg wire through.
thanks
Old Apr 25, 2007 | 03:12 PM
hillbillyinOhio's Avatar
Default RE: Where to go through the firewall?
sit in the pass front seat. where your left foot sits, right above that, rught under the edgeof the carpet is a grommet that the anenna wire goes through. you can fit 2 1/0 gauge wires through that hole.
Old Apr 25, 2007 | 03:20 PM
eshballa5's Avatar
eshballa5 is an unknown quantity at this point
You can just stick a screwdriver through that grommet too that way you still have a seal there. Don't completley take off the grommet from the antenna cable. Stick it about 3 ft through and you should see it dangling down through the firewall.
Old Apr 25, 2007 | 06:12 PM
EuroGoldLS's Avatar
EuroGoldLS is on a distinguished road
There is also a way to feed it by the steering column isn't there?
Old Apr 25, 2007 | 06:37 PM
there are a few different places, but that one is the most convenient, because it is a straight shot from the battery and uses the least amount of cable.(esp useful when the wire you are using can cost as much as $4 bucks a foot or more)
Old Apr 25, 2007 | 10:03 PM
eshballa5's Avatar
ditto to hillbilly. plus the less wire you use the more voltage and current you can get to your amplifier. Which in english means more output. You said you were using 10ga. i would step up to at least 8ga. It will give you a couple more dB.
joshn444
Apr 25, 2013 08:05 AM
carterx
Nov 30, 2009 01:39 AM
offroadwnc
Oct 19, 2009 10:47 PM
djkrash
Jan 8, 2008 03:23 PM
EuroGoldLS
Jun 15, 2007 04:11 AM
