testing speakers with a 9v battery?
Old Apr 19, 2007 | 06:56 PM
kerander's Avatar
kerander is an unknown quantity at this point
Default testing speakers with a 9v battery?
I saw a thread where someone said you can test if the wiring to the speakers is ok by touching the speaker wires to the pos. and neg. leads of a 9v battery. My question is, how do you know which ones of the little female acceptor slots on the factory harness to touch? Is there a diagram somewhere to reference? Or does anyone know which is which?
Old Apr 19, 2007 | 09:03 PM
kerander's Avatar
Default RE: testing speakers with a 9v battery?
installdr.com
Old Apr 20, 2007 | 02:07 AM
eshballa5's Avatar
eshballa5 is an unknown quantity at this point
Are you trying to test it at the speaker or at the rear of the deck. the 9v is to check to see if a speaker is working. if you disconnect it at the speaker and touch the 9v to the speaker wires then you could screw something up.
Old Apr 24, 2007 | 02:18 PM
kerander's Avatar
Uh, I guess I just want to know if the speaker is working (rather than a faulty output channel on the HU) in the easiest way.
Old Apr 24, 2007 | 03:19 PM
hillbillyinOhio's Avatar
factory or aftermarket deck? really only way isto either cut the wires behind the HU and(need to know which speaker is suspect for wires) or pull the panel off and check the speaker there.
Old Apr 25, 2007 | 10:35 PM
twei's Avatar
twei is an unknown quantity at this point
can you test the tweeters with a 9v aswell?
Old Apr 26, 2007 | 12:41 AM
eshballa5's Avatar
sure you just have to listen a little more closely. you'll hear more of a tick than a pop
Old Apr 26, 2007 | 04:35 AM
kerander's Avatar
factory HU
I can pull off the panel no prob. So I just solder on some wires to the battery terminals and touch them to the connections on the speaker?
Old Apr 26, 2007 | 04:38 AM
just take a length of speaker wire, strip off a section, tape them to the battery, and there you go. ghetto speaker tester!
Old Apr 26, 2007 | 01:45 PM
eshballa5's Avatar
Hey sometimes ghetto is all you need. i use that sort of stuff around the shop all the time. i know you do too hillbilly.
lionel2
Mar 13, 2008 01:09 PM
BobTheBlazer
Jan 24, 2008 05:54 PM
Whutdidyousay
Oct 16, 2007 09:50 PM
fjdavid
Aug 16, 2007 07:32 AM
dax44
Dec 26, 2006 08:39 PM
