wiring in interior neons
Old Aug 30, 2007 | 07:02 PM
  #21
Default RE: wiring in interior neons
The purpose of the relay is to only use the courtesy circuit to actuate the relay. Nothing more. It'll only take like 0.1amps to actuate the relay depending on the amperage of the relay.
Get yourself a small project box and mount everything inside the box with only the wires coming out. Be sure to choose the appropriate sized wire and relay for the load you will be putting on it. Light duty wires can be used for the non-loaded side of the relay, but the load side will need to have wire large enough for the load.
Old Aug 30, 2007 | 07:07 PM
  #22
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
ORIGINAL: swartlkk
Um... That isn't how a 5 pin relay works. A 5 pin relay has a normally closed pin and a normally open pin. When the relay is not energized, the NC pin is closed and the NO pin is open. When energized, the NC opens and the NO pin closes.
Check this out: the12volt.com\Relays
And all you need is a single throw switch and a SPST relay, but SPDT relays are more common. Do you know what you are going to be using for amperage? If you put in a 30amp fuse, I'd have atleast a 30amp relay... But you may want a relay that is rated for continuous duty or get a 60amp relay to beef it up.
thank you kyle.... for some reason, I had a gut feeling that I was wrong...lol
mortalum620
Aug 30, 2007 02:27 PM
EuroGoldLS
Jul 29, 2007 11:23 AM
blazinloud
Feb 1, 2007 11:22 AM
98BlackBlazer
Nov 7, 2006 08:38 PM
blazerrider101
Oct 29, 2005 04:53 AM
