XM SkyFi problem
Old Jan 28, 2008 | 10:12 AM
numus's Avatar
numus is an unknown quantity at this point
Default XM SkyFi problem
I have an XM skyfi that i have hooked up to my stock delco radio via a belkin tunecast II fm transmitter.. This transmitter works great except with the skyfi reciever i get a static in the background.. i have attributed this static to the car power adapter.. Does this make any sense that the power adapter is causing a static sound in the background of the radio or is it more then likely the skyfi radio is just bad?
Old Jan 28, 2008 | 01:22 PM
xmradioguy's Avatar
xmradioguy is an unknown quantity at this point
Default RE: XM SkyFi problem
I would try a different line out cable from the cradle to the fm modualtor. Then you can narrow the problem down more if that doesn't fix it. Also 1 more thing the skyfi is old and the newer receivers have better sound quality as the skyfi doesn't process the newcodecs that XM uses as well as the newer generation receivers.
Old Jan 30, 2008 | 05:02 AM
numus's Avatar
ya i purchased a skyfi2 on ebay the other day.. figured it was about time to replace the skyfi unit and also i want to use the antenna adapter which requires the built in fm transmitter
Old Jan 30, 2008 | 02:05 PM
XBlazer01's Avatar
XBlazer01 has a spectacular aura aboutXBlazer01 has a spectacular aura about
ORIGINAL: xmradioguy
Interesting name........ You work at XM?????
But yea you should look into the FM modulation. will eliminate the static as it plugs directly into the antenna port on the radio.
Old Jan 31, 2008 | 11:00 PM
numus's Avatar
so i was going to wire in a 12 volt plug through a new amp in my fuse box but couldnt figure out how to add the new circuit and get power to it so instead i tied it into the radio harness 12volt and ground.. am i going to exprience any problems in the future? i did this so i can hide the xm plug behind the headunit instead of using up an outlet...
also now i get a whine in the static that increases in pitch when i rev the engine
Old Apr 3, 2008 | 11:13 PM
xmradioguy's Avatar
ORIGINAL: XBlazer01
I can't confirm or deny that.
Old Sep 3, 2008 | 11:57 PM
klote82's Avatar
klote82 is an unknown quantity at this point
sirius owns!
96realwe
Dec 10, 2010 09:19 AM
English5
Jul 16, 2010 11:11 AM
Confuused69
Aug 2, 2009 11:53 PM
numus
Feb 14, 2008 10:01 PM
Daytripper540
Mar 29, 2007 03:54 PM
