skyfi xm module not fitting
Old Feb 14, 2008 | 07:50 PM
numus's Avatar
numus is an unknown quantity at this point
Default skyfi xm module not fitting
So i have this XM skyfi FM module that goes between the antenna and has power output to the skyfi2 unit and audio input in it... now... the antenna adapter does not fit in the back of the headunit.. any ideaS?
Old Feb 14, 2008 | 08:24 PM
hillbillyinOhio's Avatar
Default RE: skyfi xm module not fitting
you need two antenna adaptors. 40GM10 and 40Gm20. But you can get it together and get the 40GM30
This is because GM has the mini barb antenna. those parts will convert the gm mini barb to a normal size to plug into the XM unit, and then the other to go into the radio.
Old Feb 14, 2008 | 08:32 PM
numus's Avatar
That is really cheap... i mean i payed a lot for this stuff and i have to keep paying for adapters and crap.. now i have to shell out 20 bucks for these barbs.. and the antenna wires are so long and now i have to add something to extend those.. i think i am going to stick with the fm transmitter in the skyfi2
Old Feb 14, 2008 | 10:01 PM
you will lose a great deal of signal strength. not really to extend anything, but to convert ends.
sledneck16
Sep 8, 2009 08:59 AM
numus
Sep 3, 2008 11:57 PM
ratwell
Dec 16, 2007 09:50 AM
dimmuborgir6nik6
Dec 6, 2007 01:58 PM
scottyk
Jun 23, 2007 04:13 PM
