Xtreme OEM stereo ?s
Old Oct 11, 2009 | 01:16 PM
tcash78's Avatar
tcash78 is on a distinguished road
Default Xtreme OEM stereo ?s
I recently picked up a 2002 Blazer Xtreme and I am trying to hook up an infinity Basslink II sub to the factory system (until I can get a new head unit). The truck has the RDS Head unit and 6 speaker setup. I am trying to figure out if this model of the blazer has the OEM amplifier or not. From what I have found online the RDS head unit has an external amp but I cannot locate it. Alldata.com says it should be in the center console. However, I took out the console and there is nothing in there. How can I tell if I do have the external amp and where is it located?
Thanks
Old Oct 11, 2009 | 04:57 PM
Zeeke98's Avatar
Zeeke98 is on a distinguished road
There is no external amp on a standard RDS radio. I pulled mine out and put an aftermarket deck in. It's just a double din radio with different wiring than older GM radios. Maybe if it was a Bose system or something it might have an external amp.
Old Oct 11, 2009 | 07:12 PM
Biohazed's Avatar
you may want to look into one of those boxes that you can tap into a speaker line and it will give you the RCAs to hook the amp up, and just hook the amp turn on to the radio power for now
Old Oct 12, 2009 | 05:48 AM
tcash78's Avatar
I figured that there wasn't an amp in there but I got a little thrown with the six speakers and alldata.com didnt show a six speaker setup without an amp. Also crutchfield made a big deal with the system having RDS. I've tried tapping into the high level input for the basslink but when I hook all four input in the sub cuts off. Guess I'll have to do a rewire and see if I missed something.
Old Oct 12, 2009 | 07:12 PM
Zeeke98's Avatar
What wires are you tapping into? The 6 speakers consists of 2 tweeters in the dash, two in the doors and 2 in the rear doors or side panels depending if you have a 2 door or 4 door.
Old Oct 15, 2009 | 04:44 AM
tcash78's Avatar
I first started with just tapping at the two rear speakers. That worked but when the volume was turned up to medium volume the bass would cut out. Then I tapped the front speakers directly behind the radio. As soon as I plug those connections in, the bass cuts off instantly.
I also forgot to mention that the head unit is the indash six disc cd unit. Not sure if that helps in figuring on wether there is a factory amp.
Thanks guys
ghostriderjp
Aug 18, 2011 01:50 PM
manekDC2_
Nov 5, 2010 02:55 AM
salvy
Nov 24, 2008 05:49 AM
skybum02
May 29, 2007 01:58 PM
