1993 S-10 Blazer 4X4
Old Dec 20, 2017 | 08:03 AM
  #21
'93BLZR's Avatar
'93BLZR is on a distinguished road
Holy crap this column is hacked. Broken plastic piece of the top, locking plate cover is bent, and it just all looks terrible
Old Dec 20, 2017 | 08:04 AM
  #22
'93BLZR's Avatar
I will have to find another column to transplant some parts
Old Dec 20, 2017 | 08:10 AM
  #23
stevbre1's Avatar
stevbre1 is on a distinguished road
That sucks. I’m sorry. It might be easier to just switch out the whole steering column with one from a junkyard.
Old Dec 20, 2017 | 08:47 AM
  #24
'93BLZR's Avatar
Maybe a little too invasive for my liking.. I guess... Having to do it on a ranchero is already difficult. I think all I need is a locking plate cover(its the metal piece) And i'll have to ignore the broken plastic piece on the column collar, which bothers me WAYY more than it should.. I'll take some pics and show whats hacked
Old Dec 20, 2017 | 08:28 PM
  #25
stevbre1's Avatar
Having any broken plastic on it would bother me a lot too. You might be able to find something to cover it up with, if you don't want to replace the entire column. I know I wouldn't want to do the work to replace it either. You can actually take the locking plate off altogether if you can't find a replacement. When I first got my '88 S10, my brother mangled the lock plate trying to get it off to replace the ignition cylinder, so we just left it off, and it was fine.
Old Dec 21, 2017 | 08:44 AM
  #26
'93BLZR's Avatar
Look in the first gen tech help thread under "general tech help" it's called "locking plate won't come out!!" I took pics of what is bent. Whatever it is is keeping me from removing the locking plate. And I was actually lucky enough to find a repair kit for with broken on the column. It's only $24
Old Dec 21, 2017 | 05:25 PM
  #27
'93BLZR's Avatar
Got the dang cover off. Found the torx screws holding it in. Replaced ignition and it runs now. Little smoky.. maybe bad pcv valve or worse. Everything went together fine. Now to remove the alarm completely and address the transmission leak. Transfer case is also hanging. Will definitely need some help from here with that
Old Jan 18, 2018 | 12:00 PM
  #28
'93BLZR's Avatar
UPDATE!:
Ok, I figured that I would give everyone an update on the Blazer... As of now, it is back in the shop because the starter died on me. HOWEVER, I have gotten the ignition and door locks switched out, transfer case and transmission have been rebuilt, oil and fuel pump changed, I will be doing LIM gaskets and valve seals soon. I've gotten the interior cleaned up, and it looks like new!(I've also given the radio a facelift with the chrome buttons and shiny faceplate from a '89 Cutlass) 4WD seems to work well, but tires are way too big to work for that truck. It has a 5-inch lift, heavy duty springs and shocks, and plenty of other off-road upgrades.... I will be getting the registration on the truck as soon as I get it back. I'm reluctant to put many miles on it, considering its just barely at 150k, but it will be my daily driver. I'm also planning to begin paint correction and undercoating the body...
Old Jan 18, 2018 | 04:50 PM
  #29
stevbre1's Avatar
UPDATE!:
That sounds awesome. Sounds like you’ve been busy! With as much work as you’ve done on it, don’t be reluctant to put miles on it. Drive it as much as you want. I can’t wait until I have my Bravada finished so I can make it my daily.
What are you planning on using for paint correction? I used Meguiar’s Ultimate Compound to shine up the paint on mine, but I still need to do a more thorough exterior detailing. Also, IronX is good for dissolving brake dust on the aluminum wheels.
Old Jan 19, 2018 | 10:48 AM
  #30
'93BLZR's Avatar
That sounds awesome. Sounds like you’ve been busy! With as much work as you’ve done on it, don’t be reluctant to put miles on it. Drive it as much as you want. I can’t wait until I have my Bravada finished so I can make it my daily.What are you planning on using for paint correction? I used Meguiar’s Ultimate Compound to shine up the paint on mine, but I still need to do a more thorough exterior detailing. Also, IronX is good for dissolving brake dust on the aluminum wheels.
I plan on using something by Mother's or Meguiar's. But I have to take it to a commercial car wash first because I've already washed it 4 times and it still looks like the day it did when I first picked it up... (covered in dust) A car wash near me has an extremely effective wash soap, and I can also shampoo the carpets and shine up the engine bay
1993 S10 BLAZER 4X4 CPI
Sep 16, 2012 11:28 AM
reddheadnla
Apr 23, 2011 11:08 AM
reddheadnla
Apr 4, 2011 06:27 PM
chevyman09
Dec 7, 2008 07:58 AM
Goliath Jr
Aug 30, 2007 10:01 PM
