1994 Blazer S10 4x4 - Rebuild and pimp
Old Jan 23, 2016 | 04:48 PM
rriddle3's Avatar
*I have combined the two separate threads about this build to avoid confusion and so the entire process can be seen.*
Old Jan 24, 2016 | 03:34 AM
Great - Thanks a lot!
Old Feb 2, 2016 | 02:01 AM
Build is on it's way.
The first step now is to find out if there are reasonable priced aftermarket crankshafts for this engine.
The one pulled from the engine has yet to be identified. As it shows some ruts on the mains it will probably take quite some grinding to fit oversized bearings. As this means grind, nitrate, and fit equals cost I'm looking for a replacement.
Old Feb 22, 2016 | 02:28 AM
Engine is fully apart now. Heads are the headache at the moment. Chris015's tip could work out. Ill figure that and see if i can pull a pair of heads on a junk-yard.
Else I'll work with my heads and fine-tune them. The already have the "Vortec" runners but not yet the heart-shaped combustion chamber.
Once I have built a sturdy base and the valvetrain I can change the heads also at a later time. Or even better I can build the engine I pull from my drive once I have this one running.
More on that at the moment still at:
http://www.crankshaftcoalition.com/w..._balance_shaft
Darealcasanova
Feb 2, 2016 10:23 PM
AlaskanK5
Jun 26, 2010 02:26 PM
boomtruck97
Jun 24, 2010 04:09 PM
mech cb
Sep 16, 2009 06:00 AM
m00nwater
Mar 30, 2005 11:34 PM
