1999 Sandblazer Build
Old Jul 11, 2016 | 06:40 AM
Tajohns34's Avatar
The switches look good. Nice work on the wiring, it is very clean.
Old Jul 11, 2016 | 05:53 PM
cdtek101's Avatar
cdtek101 is on a distinguished road
Thanks.
Old Jul 11, 2016 | 10:24 PM
tenorsaxdude's Avatar
tenorsaxdude is on a distinguished road
Wow love the switches, they look great!
Old Jul 12, 2016 | 05:15 AM
cdtek101's Avatar
Thanks...
Old Nov 7, 2016 | 04:26 PM
bjcarr169's Avatar
bjcarr169 is on a distinguished road
Wow the rocker panels look awesome along with the switches. Where did you get the switches ?
Old Nov 7, 2016 | 08:38 PM
cdtek101's Avatar
Thanks... got all from Amazon -
Rocker Panel:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Rocker: LED light bar W/ harness
Rocker: Dual USB / Voltage meter
Rocker: Stereo amp
Rocker: Interior Lights
Old Dec 19, 2016 | 06:14 PM
cdtek101's Avatar
Got the Upper / Lower Control arms with new ball joints
and bushings done on both sides along with new shocks
and torsion bar mounts. So that completes all suspension
and steering needed items.
Attached Thumbnails 1999 Sandblazer Build-u1.jpg   1999 Sandblazer Build-u2.jpg
Old Dec 29, 2016 | 01:07 AM
cdtek101's Avatar
Angry Blazer down
Christmas eve -
Something bad sounding like a broken push rod or rocker arm
anyway something is noisy and rattling in drivers side top of
engine...so parked in garage for now.
Old Jan 28, 2017 | 08:28 PM
cdtek101's Avatar
Well I found a replacement engine and ordered
the parts below to freshen it up. Taking to shop
Monday 1/30/2017 for engine swap mission. I will be
glad to be back on the road again.....
Crankshaft Rear Main Seal - Enginetech SK5007
Engine Gasket Set - Victor Reinz 953491VR
Oil Pump - SEALED POWER 22443469
Oil Pump Intermediate Shaft - SEALED POWER 2246146E
Oil Pump Screen - SEALED POWER 22415050
Oil Cooler Gasket - FEL-PRO ES70016
Serpentine Belt - DAYCO 5060950
Thermostat - STANT 45119
Water Pump - ACDelco 252-711 Professional
Distributor Cap - ACDELCO D328A
Distributor Rotor - ACDELCO D465
Ignition Coil - DELPHI CE20003
Spark Plugs - NGK 7164 Iridium IX
Spark plug wire set - SMP OE Plus Direct Fit; Premium 7 mm
Old Jan 29, 2017 | 04:03 PM
cdtek101's Avatar
Did a RPO Code report on my Blazers Vin:
Vehicle : BLAZER 4 DR
Year : 1999
Build Date : 02/25/1999
RPO Description
11U EXTERIOR COLOR,PEWTER MET (11U)
1SD PACKAGE-OPTION 04 (1SD)
6WH COMPONENT FRT LH COMPUTER SEL SUSP (6WH) SUSP(6WH)
7WH COMPONENT FRT RH COMPUTER SEL SUSP (7WH) SUSP(7WH)
91A STRIPE,COLOR ACCENT,TWO TONE,BEIGE/RED (91A)
92H TRIM COMBINATION CLOTH, MED DARK PEWTER (97) (H) (92H)
92I INTERIOR TRIM SHALE/PEWTER (92I)
A31 WINDOW,POWER OPERATED,ALL DOORS PWR WINDOWS(A31)
AG0 ADJUSTER SEAT, POWER, 8 WAY, 2 POSITION MEMORY, DRIVER 8 WAY POWER MEMORY ST ADJ(AG0)
AH8 ADJUSTER PASS ST POWER,8 WAY 8 WAY PWR ST ADJ(AH8)
AJ1 GLASS,DEEP TINT(REAR SIDE WINDOWS AND REAR DOOR WINDOW) DEEP TINTED GLS(AJ1)
AN3 SEAT FRT, INDIVIDUAL/NON-BKT INDIVIDUAL FRT SEAT(AN3)
ANL PACKAGE,AIR DEFLECTOR AND FOG LAMPS A/DFL & FOG LP PKG(ANL)
AP9 NET,CONVENIENCE CONVENIENCE NET(AP9)
AU0 LOCK CONTROL,REMOTE ENTRY(KEYLESS ENTRY SYSTEM) REMOTE ENTRY LK CONT(AU0)
AU3 LOCK,SIDE DOOR,ELECTRIC ELEC S/D LK(AU3)
AXP VIN IDENT POSITION, MULTI- PURPOSE VEHICLE MULTI-PURPOSE VEHICLE VIN POSITION(AXP)
B30 CARPET,FLOOR AND WHEELHOUSE FLR CPT(B30)
B84 ORNAMENTATION,EXTERIOR,BODY SIDE MOLDING BODY SI MLDG(B84)
C25 WIPER SYSTEM,REAR WINDOW RR WDO WPR(C25)
C3T GVW RATING 5350 LBS 5350 GVWR(C3T)
C68 AIR CONDITIONER,FRONT,AUTOMATIC,ELECTRONIC CONTROLS A/C AUTO ELEC CONT(C68)
D55 CONSOLE,FRONT COMPARTMENT FLOOR F/CMPT FLR CNSL(D55)
D96 STRIPE,BODY SIDE UPPER ACNT STRPE(D96)
DD0 MIRROR,O/S,R AND L REM CTL,ELEC,DEFOG,LT SENSITIVE O/S ELEC R/CON MIR(DD0)
DD8 MIRROR,INSIDE,REARVIEW,TILT,AUTOMATIC,LIGHT SENSITIVE I/S RR VIEW MIR,LIGHT SENSITIVE(DD8)
DH2 MIRROR,INSIDE, ILLUMINATED,LH & RH,WITH DUAL SUNSHADE ILLUM S/S MIR(DH2)
DK8 CONSOLE ROOF INTERIOR, DELUXE ROOF CONSOLE(DK8)
E55 GATE,END END GATE(E55)
EVA TEST DVT, EVAP EMISSION REQUIREMENT EVAP EMISSIONS REQUIRED(EVA)
FE9 FEDERAL EMISSION CERTIFICATION FED EMIS(FE9)
FF6 ARM,TORSION BAR SPRING ADJUST,LH TORS BAR ADJ ARM(FF6)
FF7 ARM,TORSION BAR SPRING ADJUST,RH TORS BAR ADJ ARM(FF7)
G80 AXLE,REAR,POSITRACTION,LIMITED SLIP POSITRACTION L/SLIP R/AXL(G80)
GT4 AXLE,REAR,3.73 RATIO 3.73R(GT4)
JC1 BRAKE VAC POWER, 4 WHL DISC, 5,500 LBS BRAKE VAC PWR(JC1)
K34 CRUISE CONTROL,AUTOMATIC,ELECTRONIC CRCONT(K34)
K60 GENERATOR,100 AMPERE 100 AMP(K60)
L35 ENGINE,4.3L(4.3W),CPI,V6,90 DEG 4.3W(L35)
LIN PLANT CODE-LINDEN, NEW JERSEY (CPC) LINDEN, NJ PLANT CODE(LIN)
M30 TRANSMISSION,AUTOMATIC 4 SPEED,4L60E,ELECTRONIC 4-SPD A/TRANS(M30)
N33 STEERING COLUMN,TILT TYPE TILT STRG COL(N33)
N40 STEERING,HYDRAULIC(NON-VARIABLE) NON-VARIABLE P/S(N40)
N90 WHEEL,15X7(CAST ALUMINUM) AL WHL(N90)
NF2 EMISSION SYSTEM,FEDERAL,TIER 1 FED EMIS SYS(NF2)
NP5 STEERING WHEEL,LEATHER WRAPPED LEATHER WRAPPED STRG WHL(NP5)
NP8 TRANSFER CASE ACTIVE, TWO SPEED, PUSH BUTTON CONTROL TRANSFER CASE(NP8)
QBG TIRE ALL P235/70R15 WOL R/PE ST TL ALS 102S TIRE(QBG)
RSA RESTRAINT - FRT SEAT, 208, AUTO, PASSIVE
RYJ COVERING,CARGO AREA,RETRACTABLE RETRACTABLE CARGO CVR(RYJ)
SLM SALES PROCESSING - STOCK ORDERS
T61 LIGHTING,DAYTIME RUNNING DAYTIME RUNNING LGT(T61)
U16 TACHOMETER,ENGINE TACH(U16)
U73 ANTENNA,FIXED FIXED ANT(U73)
UA1 BATTERY,HEAVY DUTY HVY DUTY BAT(UA1)
UP0 RADIO AM/FM STEREO, SEEK/SCAN, AUTO REV MUSIC SEARCH CASS, CD, AUTO TONE, CLOCK, ETR. STEREO,AM/FM W/AUTO REV CASSETTE,CD,AUTO TONE(UP0)
UP8 RADIO,PROVISIONS FOR STEREO INSTRUMENTATION STEREO RDO PROVISIONS(UP8)
UY7 TRAILER WIRING,7 WIRE,2 LEAD FRONT HARNESS,5 LEAD REAR HARNESS 7 WIRE TRLR HARN(UY7)
V54 CARRIER,ROOF LUGGAGE(PAINTED) PAINTED RF LUGG CARR(V54)
V73 VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73)
VP6 NOISE LEVEL CONTROL NOISE LVL CONT(VP6)
VR4 TRAILER HITCH(WEIGHT DISTRIBUTING PLATFORM) EQLZR HITCH(VR4)
VXS VEHICLE - COMPLETE
X88 MARKET BRAND CHEVROLET CHEVROLET(X88)(EXPORT)
XBG TIRE FRONT P235/70R15 WOL R/PE ST TL ALS 102S TIRE(XBG)
YBG TIRE REAR P235/70R15 WOL R/PE ST TL ALS 102S TIRE(YBG)
YC6 DECOR PACKAGE/CL/SLE,#6(LUXURY) DECOR PKG #6/CL/SLE(YC6)
YD3 AXLE FRONT (BASE EQUIP) FOR SCHEDULING GVW PLATE FRT AXLE(YD3)
YD5 SPRING,FRONT(BASE EQUIPMENT) FRT SPRING(YD5)
YD6 SPRING,REAR(BASE EQUIPMENT) RR SPRING(YD6)
Z82 TRAILERING PACKAGE(SPECIAL)(REESE TYPE HITCH) PROVISION FOR HD TRAILER EQUIP(Z82)
ZBG TIRE SPARE P235/70R15 WOL R/PE ST TL ALS 102S SPARE TIRE(ZBG)
ZM5 SHIELD PACKAGE,UNDERBODY U/B SHLD PKG(ZM5)
ZM8 PACKAGE,ELECTRIC TAILGATE RELEASE AND REAR DEFOGGER ELEC T/GATE REL & RR DEFG PKG(ZM8)
ZQ3 DRIVER CONVENIENCE PACKAGE II(MERCHANDISING OPTION) DRVR CONVENIENCE PKG(ZQ3)
ZQ6 DRIVER CONVENIENCE PACKAGE III DRVR CONVENIENCE PKG III(ZQ6)
ZW7 CHASSIS PACKAGE,PREMIUM SMOOTH RIDE PREMIUM SMOOTH RIDE CHAS PKG(ZW7)
ZY1 COLOR COMBINATION SOLID SOLID PAINT COMBO(ZY1)
