1'st Gen Build - Frankenblazer
Old Feb 17, 2015 | 10:26 AM
Maltasrc's Avatar
Maltasrc is on a distinguished road
Here are a couple of close up pics of the body mount relocation.
This one needed to be mover forward 1"
*IMG*
And this one needed to be moved back 1"
*IMG*
Attached Thumbnails 1'st Gen Build - Frankenblazer-img_0060_zps6f61378e.jpg   1'st Gen Build - Frankenblazer-img_0058_zps66ba548a.jpg
Old Feb 19, 2015 | 08:41 AM
Maltasrc's Avatar
Well, Got the motor on the chassis. New pilot bearing, flywheel, clutch and slave cylinder and installed.. Then mated up the transmission (what a pain in the *** that was to do solo)
*IMG*
*IMG*
Attached Thumbnails 1'st Gen Build - Frankenblazer-img_3242_zps9ad5442a.jpg   1'st Gen Build - Frankenblazer-img_3255_zps1851c185.jpg
Old Feb 19, 2015 | 08:44 AM
Maltasrc's Avatar
So i guess my next task will be to install the gas tank and run new fuel lines.. After that I will start to work on the exhaust..
Old Aug 18, 2018 | 07:47 AM
aellier's Avatar
aellier is on a distinguished road
I know it has been forever since you were on this thread, but I am getting ready to start a very similar job. I have a 90 4 door blazer that I am looking to put onto a 98 4 door chassis. If you could give me any pointers, or maybe even an update on your build that would be awesome. Thanks
Old Aug 19, 2018 | 05:06 PM
Maltasrc's Avatar
Sure, I can give an update. Its been a long time and the truck has evolved quite a bit. I did step away from it for almost 2 years due to a move and career change that really threw me for a loop. But by chance, I happen to have started working on it just this year.
Old Aug 19, 2018 | 05:09 PM
Maltasrc's Avatar
Old Aug 19, 2018 | 08:50 PM
Radar696's Avatar
Radar696 is on a distinguished road
I find it very interesting that your truck appears to have a wood fired heater!
Well be sure to keep your thread up to date.
I myself am not looking at such a build but I'm sure there are many that will be looking for tips and tricks.
Good luck!
Radar
Old Aug 20, 2018 | 07:39 PM
aellier's Avatar
That looks awesome, how bad was it to get everything lined up on the newer chassis?
Old Aug 20, 2018 | 08:12 PM
Originally Posted by Maltasrc
My plan was to take the hose (98 style with the press in fitting) and go to my local hydraulic shop to have them add a fitting to the master end. currently the hose is part of the 98 master and doesn't have a fitting like the 89 would.
The question - are there adapter hoses available or am I forced to go custom?
Did you ever get this figured out? I used a Russell adapter fitting at the master cylinder end, then used a -3 braided hose to the slave cylinder. I have an aftermarket slave cylinder, though. I'm not sure if there's any way to adapt the braided hose to your stock slave cylinder.
Old Aug 23, 2018 | 10:25 PM
Maltasrc's Avatar
nothing to it. Everything lined up and I only needed to slightly move 4 body mounts roughly 1/2"
