2000 Boring Blazer Build
Old Mar 17, 2014 | 01:31 PM
  #131
Tajohns34's Avatar
So I haven't updated in a while. Since I have gotten the crank position sensor and the distributor replaced, the oil pressure was reading really low, so I figured I would start with the oil pressure sensor. I bought the special socket and had a heck of a time getting it out anyway. What had happened was that i had it on crooked and I broke the sensor, all that was left was the end of it where it screwed in. So I pulled the distributor out and got a 1 1/16" wrench to get it off.
Once I did that replacing the sensor was simple. However putting the distributor back in was not. I marked the location of the rotor and the location of the rotor when I pulled it out. However, it would not go back in the right place. What happened was that the oil pump shaft somehow got shifted. So I got long Flathead screwdriver and
moved it where it needed to be.
needs to be about 45 degrees counter clockwise
Attached Thumbnails 2000 Boring Blazer Build-20140317_170955_zps8878af20.jpg   2000 Boring Blazer Build-20140309_170509_zpsb958952d.jpg   2000 Boring Blazer Build-20140309_174244_zpsbf57f2f7.jpg   2000 Boring Blazer Build-20140310_165051_zpsdc7dac1a.jpg   2000 Boring Blazer Build-20140310_165120_zpsde8e2cc3.jpg
Old Mar 17, 2014 | 01:36 PM
  #132
Tajohns34's Avatar
Getting the screwdriver on the shaft isn't as easy as I though. i couldn't tell when I was on it because it is on the back of the engine and the screwdriver was in my way. I had to use my camera to see where I was. Once I got it on there it turned very easy, and the distributor when right back in.
Attached Thumbnails 2000 Boring Blazer Build-20140310_165245_zpsb84de720.jpg   2000 Boring Blazer Build-20140310_165349_zps0ffc5eab.jpg   2000 Boring Blazer Build-20140310_165422_zps2e21ecda.jpg
Old Mar 18, 2014 | 11:09 AM
  #133
Tajohns34's Avatar
About a month ago my e fans were staying on all the time and killing my battery. So I pulled the controller box out and found that it was full of water and ice. Here is what I found inside
This was all garbage
The fuse holders only hold up to a 30 amp fuse, which I didn't notice until they partially melted and didn't blow the 40s that I had put in there.
The relays and holders didn't fair any better
Attached Thumbnails 2000 Boring Blazer Build-20140317_172532_zps5818d9ab.jpg   2000 Boring Blazer Build-20140317_172519_zps4b81baf7.jpg   2000 Boring Blazer Build-20140317_1725091_zps286ba553.jpg   2000 Boring Blazer Build-20140317_172432_zps2bb32959.jpg   2000 Boring Blazer Build-20140317_172419_zpsf273c044.jpg
Old Mar 18, 2014 | 01:22 PM
  #134
newguy's Avatar
Wow, glad you caught it before something bad happened
Old Mar 18, 2014 | 02:23 PM
  #135
Tajohns34's Avatar
me too! So basically i rewired it with new fuse holders, 30 amp fuses, new relays and wiring. I didn't use fuse holders this time. After I put it all back together I sealed it with silicone. The wiring is the same as before.
Attached Thumbnails 2000 Boring Blazer Build-20140131_223219_zps11490601.jpg   2000 Boring Blazer Build-20140131_225403_zps30f5da16.jpg   2000 Boring Blazer Build-20140201_002249_zps051ece86.jpg   2000 Boring Blazer Build-20140201_002300_zps5b49ec37.jpg   2000 Boring Blazer Build-20140201_014525_zpsf79b5c5c.jpg
Old Apr 16, 2014 | 10:21 AM
  #136
Tajohns34's Avatar
So, when I first got my blazer it had a K&N filter in it and it kept throwing a code for a bad MAF sensor. So I got rid of the K&N and replaced it with a stock filter and cleaned the MAF with MAF cleaner. I was still having issues which I attributed to the leaky and falling apart stock air box that was never replaced after an accident. So I got a CAI and cleaned it again. Now I haven't gotten the code since but it still just didn't run right since I've had it, especially when it is cold. So I got this MAF Sensor.
I know it looks a lot cheaper than the stock metal one, but it works great. My engine runs better than it ever has.
Attached Thumbnails 2000 Boring Blazer Build-20140303_172215_zpse666379b.jpg   2000 Boring Blazer Build-20140303_173010_zpsb16dfbe4.jpg   2000 Boring Blazer Build-20140303_173123_zps44730a88.jpg   2000 Boring Blazer Build-20140303_173447_zps52bc7c1b.jpg
Old Apr 29, 2014 | 06:33 AM
  #137
Tajohns34's Avatar
So, I have developed a rod knock so I am replacing my engine. I already orded a used engine with 114k on it. It needs intake gaskets. Should I get new intake bolts with the gasket kit?
Old Apr 30, 2014 | 07:58 AM
  #138
Dark Rider's Avatar
Dark Rider is on a distinguished road
I replaced my intake manifold gasket back in November. When I was researching the process, a lot of people online said to replace the bolts. I don't remember the Haynes manual saying either way. But, some logical advice I got from a mechanic: the bolts you take out have been torqued and stretched to fit, replacing with new ones may or may not create a leak.
I ended up not replacing the bolts, instead taking a gamble on the old ones, and so far I have had no problems.
Good luck.
Old Apr 30, 2014 | 10:36 AM
  #139
Tajohns34's Avatar
I heard the same thing, but I figured since they are cheap they may be worth replacing. Thanks for the heads up.
Old May 1, 2014 | 08:15 AM
  #140
Tajohns34's Avatar
I was thinking that since the engine is out that it might be worth it to replace the motor mounts. I checked a bunch of parts stores and websites but I can only find a bunch of brands that I have never heard of. Anchor seems to be a popular brand to sell but from what I am reading they aren't very good. Can anyone recommend a good brand and where to get them?
