2000 Boring Blazer Build
Old Jan 7, 2014 | 04:32 AM
  #111
HotRodHearseGuy's Avatar
HotRodHearseGuy is on a distinguished road
I had a similar problem some time ago with the original engine and then one day out running errands, it wouldn't start at all. Towed it home, replaced the fuel filter, still no fire. Looked under the front at the crank position sensor and had a broken wire. It's possible you could have dirty spots on the crank and the sensor can't read. Try spraying it down and cleaning the crank pulley and area.
Old Jan 7, 2014 | 09:18 AM
  #112
Tajohns34's Avatar
It isn't cranking at all.
Old Jan 23, 2014 | 10:38 AM
  #113
Tajohns34's Avatar
So I know I haven't updated this in a while. I have been super busy with work, and it has been cold. I have been trying to figure out 2 issues. I have been going through about a gallon of coolant a week and an intermittent no crank issue. So I finally gave up trying to trouble shoot it. I took it to a reputable shop near me that I have gone to before. Turns out that the issues are related. The intake manifold is leaking coolant out the back. Which is leaking all over the wiring and the neutral safety switch, which they believe is causing the no start. So its is $794 to replace the gaskets. and then we go from there. Once I get it running and I recover from emptying my bank account I will start updating more often.
Old Jan 30, 2014 | 08:58 PM
  #114
Tajohns34's Avatar
I haven't gotten a lot done the past few days because I just had my wisdom teeth cut out and i have been on pain killers. However I did get an order of Bravada ***** in from a user on S10forum.com and I installed them today. No real how to needs to be done, just pull the old ones off and put the new ones on.
old
new
I think they look way better.
Attached Thumbnails 2000 Boring Blazer Build-20140130_164556_zpsf3c28060.jpg   2000 Boring Blazer Build-20140130_164646_zps02b08a75.jpg
Old Feb 4, 2014 | 02:13 PM
  #115
cbmorrell91's Avatar
cbmorrell91 is on a distinguished road
I was looking over your thread and didn't realize you live in Pa until I saw the Pinchot Park pictures haha.. I live in York
Old Feb 5, 2014 | 10:28 AM
  #116
CPLSeraphim's Avatar
CPLSeraphim is on a distinguished road
Like the look of those new *****. And had to laugh at the last post. I live in Indiana, Pa. looks like you got some PA guys watching your build.
Old Feb 6, 2014 | 05:26 AM
  #117
Tajohns34's Avatar
I am about an hour from Pinchot Park.
Old Feb 7, 2014 | 07:11 AM
  #118
Tajohns34's Avatar
For the last couple of days i have been having less and less power but no Check engine light. This morning any time the engine got to around 2k rpm it would stumble and almost stall. I can't get above 40 mph unless I am going down hill. When I was coming down the road to my office I decided to floor it. That triggered a PO339, PO339P, & PO410P code. I am running low on patience with the issues on this vehicle.
Old Feb 7, 2014 | 10:27 AM
  #119
newguy's Avatar
Clogged cat maybe
Old Feb 7, 2014 | 12:22 PM
  #120
rexmburns's Avatar
Super Moderator
The cat is the first thing that came to my mind as well!
