2000 Boring Blazer Build
Old Feb 8, 2014 | 06:51 AM
  #121
Tajohns34's Avatar
A bad cat would throw a crank position and primary air pump code?
Old Feb 8, 2014 | 08:41 AM
  #122
newguy's Avatar
sure about that?
Old Feb 8, 2014 | 09:06 AM
  #123
Tajohns34's Avatar
Would that throw a secondary air pump and crank position code? Also, my tachometer stopped working.
Old Feb 8, 2014 | 09:28 AM
  #124
Tajohns34's Avatar
Well, I have been thinking of replacing the cat mainly because the front pipe keeps getting pin holes and I am getting sick of welding them up. I am pretty sure it is the factory pipe and Cat. I just don't have the time or cash to do it right now. When I get the time I might pull it off and weld on a universal cat.
Old Feb 8, 2014 | 09:37 AM
  #125
newguy's Avatar
Sorry I thought you you where saying it would, didnt realize it was a question. Dont think so though
Old Feb 8, 2014 | 02:40 PM
  #126
Tajohns34's Avatar
I was driving it earlier and the Check engine light went off, however it still runs poorly and the tach still doesn't work. I guess it is back to the shop
Old Feb 12, 2014 | 08:49 AM
  #127
Tajohns34's Avatar
Looks like my distributor went bad. I guess I'll see how it runs when I get it back. So far I have been really pleased with this shop I have been going to. They are very good at diagnositics and don't try to sell me a bunch of stuff I don't need.
Old Feb 14, 2014 | 02:02 PM
  #128
Tajohns34's Avatar
So I got my blazer back Wednesday evening, right before the almost 2' of snow we just got. It runs great after $490 on a new distributor and crank position sensor.
Old Feb 19, 2014 | 02:21 PM
  #129
Tajohns34's Avatar
About a month ago I got
these these
after seeing a video on Youtube about them (not the same exact ones). I figured for $45.99 how bad could they be. The answer is not at all, they work great.
here they are
first I brought the seats in because it was like -10 degrees outside. I did the driver's side first and then did the write up using the passenger.
take all of your handles and random brackets off that are in the way of pulling the seat cover off.
The seat covers (at least for leather) hooks to the bottom of the seat frame, with a little convincing from a small screw driver they come off.
The back has one long clip connecting the front to the back. Pulling it apart is a bit tricky, once it is apart you can carefully walk the cover up the seat.
This is where it gets a bit tricky. The seat cover is held down by strong velcro. You have to hold the velcro on the padding while you pull the cover off, if not it will rip right off the pad.
Once you have the covers back, put your heating pad on the center section only, and then trim it to fit. One thing I like about this is that they are able to be trimmed.
Next, run the wires out to the bottom of the seat, then pull the backing off and stick them to the foam padding. What I did was start one end of it while i held the heater in place and pulled the backing off.
Attached Thumbnails 2000 Boring Blazer Build-20140124_222706_zps7b6293c5.jpg   2000 Boring Blazer Build-20140124_213335_zps0a30bff0.jpg   2000 Boring Blazer Build-20140124_215802_zps7e0e63da.jpg   2000 Boring Blazer Build-20140124_222137_zpsc2a49f39.jpg   2000 Boring Blazer Build-20140124_221835_zps3ca3bdd0.jpg
2000 Boring Blazer Build-20140124_221903_zps44629b43.jpg   2000 Boring Blazer Build-20140124_221915_zpsea588dcb.jpg   2000 Boring Blazer Build-20140124_224046_zps49af6a32.jpg   2000 Boring Blazer Build-20140124_222343_zpsc5cf7e88.jpg   2000 Boring Blazer Build-20140124_224233_zps22e6f49b.jpg
2000 Boring Blazer Build-20140124_224557_zpsdf0dc6de.jpg   2000 Boring Blazer Build-20140124_222834_zpsd71ce4ba.jpg   2000 Boring Blazer Build-20140124_223406_zpsb5dfd8cf.jpg   2000 Boring Blazer Build-20140124_222845_zps54404a20.jpg   2000 Boring Blazer Build-20140124_223308_zpscd368c9e.jpg
2000 Boring Blazer Build-20140124_225117_zps6e6faf47.jpg   2000 Boring Blazer Build-20140124_225200_zps0dabcb0c.jpg
Old Feb 19, 2014 | 02:38 PM
  #130
Tajohns34's Avatar
I zip tied the wiring and the relay to the bottom of the seat.
I didn't run the wiring under the carpet, but I plan to when the weather is warm and there isn't snow everywhere. I installed the switches in the console next to where I moved my Sirius radio. The directions call for a 5/8" bit but it is actually a 3/4"
For power I used an add a circuit and tapped the radio fuse. then I ran through the dash and under the center console to the 2 20 amp fuses that came with each seat.
Attached Thumbnails 2000 Boring Blazer Build-20140124_233919_zpsfac41a69.jpg   2000 Boring Blazer Build-20140124_233956_zps4776e817.jpg   2000 Boring Blazer Build-20140124_234726_zpscc51a953.jpg   2000 Boring Blazer Build-20140201_221247_zps4e82bff2.jpg   2000 Boring Blazer Build-20140201_232018_zpse62a15e7.jpg
2000 Boring Blazer Build-20140201_232033_zpsbd90f9ad.jpg   2000 Boring Blazer Build-20140202_002607_zps58d06847.jpg   2000 Boring Blazer Build-20140202_002616_zpsd224ffb7.jpg   2000 Boring Blazer Build-20140202_002558_zps74c56586.jpg   2000 Boring Blazer Build-20140201_232050_zps6d59db86.jpg
