2000 Boring Blazer Build
#33
So, I decided to replace my Dynomax muffler with a Flowmaster super44. I also decided to weld it this time. The only issue I have so far is that the strap that came with the Dynomax is too big for the Flowmaster and now it rattles, very annoying. However, the Flowmaster sounds a lot better as in it isn't super quiet. It is not loud at all, but it puts out a little rumble, as much as you can get with a V6 anyway. I had to use 2 extension pieces I grabbed from Advance auto parts and I painted it with black exhaust paint. Now, behold my awesome welding skills.
![](https://blazerforum.com/forum/attachments/builds-48/15625-2000-boring-blazer-build-20130602_135051_zpsfcf8d99a.jpg?dateline=1371561599)
![](https://blazerforum.com/forum/attachments/builds-48/15626-2000-boring-blazer-build-20130602_135045_zps0996ca53.jpg?dateline=1371561599)
![](https://blazerforum.com/forum/attachments/builds-48/15627-2000-boring-blazer-build-20130602_135039_zps0a3159b4.jpg?dateline=1371561599)
#34
So I got my DR44G alternator a couple weeks ago for $50 on ebay. However, I got the one with a 2 pin voltage regulator. After some research I found out that you can swap the voltage regulators. So I ordered one for $41.70and I got it the other day. I also got a smaller pulley for the alternator for $20 on ebay. So I am into this alternator for $111.70
. Here are some pictures of swapping out the pulley and. voltage regulator.
Here is a blurry alternator when I first got it.
![](https://blazerforum.com/forum/attachments/builds-48/15628-2000-boring-blazer-build-20130529_194132_zps3ce9786d.jpg?dateline=1371564471)
Wow, my dad's workbench is a mess. Anwyay, I used and old belt and vice grips to hold the pulley and an impact to break the nut off. It comes right off.
![](https://blazerforum.com/forum/attachments/builds-48/15629-2000-boring-blazer-build-20130529_194204_zps8cbf213e.jpg?dateline=1371564471)
Old and new pulleys
![](https://blazerforum.com/forum/attachments/builds-48/15630-2000-boring-blazer-build-20130529_194236_zps4498dd6b.jpg?dateline=1371564471)
The new pulley goes on the same way the old one came off![](https://blazerforum.com/forum/attachments/builds-48/15631-2000-boring-blazer-build-20130529_194431_zps75373142.jpg?dateline=1371564471)
Now for the regulator
first remove the back cover
![](https://blazerforum.com/forum/attachments/builds-48/15632-2000-boring-blazer-build-20130617_174448_zps9809f291.jpg?dateline=1371564471)
![](https://blazerforum.com/forum/attachments/builds-48/15633-2000-boring-blazer-build-20130617_174602_zps8f556426.jpg?dateline=1371564471)
Removed the 3 screws (I used a 4mm 6 point socket) and the sleeve on the alternator post, it is a press on, need a lot of force and patience with this.
![](https://blazerforum.com/forum/attachments/builds-48/15634-2000-boring-blazer-build-20130617_180626_zpsaf640965.jpg?dateline=1371564471)
![](https://blazerforum.com/forum/attachments/builds-48/15635-2000-boring-blazer-build-20130617_180635_zpsdda8a173.jpg?dateline=1371564471)
Then I had to remove the solder from the connector that I am using a screwdriver to point out. Once again it took about 10 minutes to melt the solder, much patience was required.
![](https://blazerforum.com/forum/attachments/builds-48/15636-2000-boring-blazer-build-20130617_181508_zps417eef16.jpg?dateline=1371564471)
And the old regulator is off
![](https://blazerforum.com/forum/attachments/builds-48/15637-2000-boring-blazer-build-20130617_182444_zps708c86b8.jpg?dateline=1371564471)
Then I put the new one on in the reverse of how the old one came off
![](https://blazerforum.com/forum/attachments/builds-48/15638-2000-boring-blazer-build-20130617_182522_zps5a55fb17.jpg?dateline=1371564471)
I had to modify the back cover to get the new one to fit. I also cleaned off the melted plastic from the dremel tool.
![](https://blazerforum.com/forum/attachments/builds-48/15639-2000-boring-blazer-build-20130617_183427_zpse9061e97.jpg?dateline=1371564471)
Dat blur!
![](https://blazerforum.com/forum/attachments/builds-48/15640-2000-boring-blazer-build-20130617_183504_zpsf82c612b.jpg?dateline=1371564471)
![](https://blazerforum.com/forum/attachments/builds-48/15641-2000-boring-blazer-build-20130617_183511_zps4180246d.jpg?dateline=1371564471)
Now I just need to put it on, I have me 1" longer belt already.
![Frown](https://blazerforum.com/forum/images/smilies/frown.gif)
Old and new pulleys
Dat blur!
#35
I really like those parkers- where'd you get 'em? I was thinking of buying them for awhile. I found a clear pair for $35 somewhere- dont know what you paid for em. I think they look good, they really clean up the look of your front end. I think they would look great with my black bowtie!
#37
What did you use to make your fender flares??? I used rubber cove base (commercial base boards), been happy with them. I picked up a 120ft roll off CL for $20 and have plenty left over to make replacement flares. I have the same wheels, did you use the spacers with the camaro wheels???
![](https://blazerforum.com/forum/members/tommyraybradley-54551-albums-99-jimminator-6865-picture-installed-unity-h1-spotlight-26483.jpg)
#38
Chevy GMC 98 04 S10 Blazer Sonoma Bumper Lights Corner Signal Lamp | eBay
#39
Thanks Rex. I hoped to get some more done this weekend but I got roped into looking at replacing my brother in law's broken tail light on his Lexus, hopefully that won't take too long. tommyraybradley, I bouight a flexy flare kit from Amazon, I think it was around $40 or so. I had my blazer inspected when the swapped the wheels and Mr. Tire had to take off the spacers since they aren't legal in PA. I did put them back on of course.
#40
I got my alternator in this weekend. Now when my fans kick on high speed I don't drop much below 14 as opposed to barely getting 12 with the old one. once I got the old alternator out I spun it and sounded like I had a bearing going bad. So I guess it was a good time for a replacement anyway. Also the 96" long belt I got fit perfectly.
With the old alternator and both fans on high
![](https://blazerforum.com/forum/attachments/builds-48/15716-2000-boring-blazer-build-20130618_200208_zps2b56e914.jpg?dateline=1372084329)
Old alternator
![](https://blazerforum.com/forum/attachments/builds-48/15717-2000-boring-blazer-build-20130622_113542_zps41e18e85.jpg?dateline=1372084329)
No alternator
![](https://blazerforum.com/forum/attachments/builds-48/15718-2000-boring-blazer-build-20130622_124809_zps840a05aa.jpg?dateline=1372084329)
New Alternator, pulley and belt
![](https://blazerforum.com/forum/attachments/builds-48/15719-2000-boring-blazer-build-20130622_131301_zps564f3f65.jpg?dateline=1372084329)
voltage with both fans on high with the new alternator, major difference.
Old alternator
No alternator
![](https://blazerforum.com/forum/attachments/builds-48/15720-2000-boring-blazer-build-20130622_144150_zps936d05d6.jpg?dateline=1372084329)
