2000 Boring Blazer Build
Old Nov 11, 2013 | 02:14 PM
  #71
Tajohns34's Avatar
Default installing the Ebay CAI
I decided to install a cold air intake. Mainly because my stock air box was cracked from the accident before I bought it. It was working fine but it kept coming loose and leaking. Also when I did the intake I did a major cleaning of my throttle body and MAF sensor (used MAF cleaner). here are some pictures.
I probably won't be doing much until spring, I have some projects around the house and Christmas coming up. I do have a couple small projects planned for the upcoming weeks.
Attached Thumbnails 2000 Boring Blazer Build-20131102_120508_zps245dcb9a.jpg   2000 Boring Blazer Build-20131102_123554_zpsde2fbe34.jpg   2000 Boring Blazer Build-20131102_131404_zpscdf44e15.jpg   2000 Boring Blazer Build-20131104_122137_zps2ba0bb2f.jpg   2000 Boring Blazer Build-20131104_122142_zps7d21da7e.jpg
Old Nov 11, 2013 | 02:15 PM
  #72
Tajohns34's Avatar
My gas mileage went from roughly 14 mpg to 18 mpg after the intake was installed. I mainly attribute this to cleaning the MAF and the throttle body.
Old Nov 11, 2013 | 07:16 PM
  #73
Blazin00LT's Avatar
Blazin00LT is on a distinguished road
Looks like your going down the same paths I did. You even have the same crappy wrangler rt/s tires I had. Fair warning they SUCK *** in snow. Here is a link to my build.
Lets make it better then when I got it.
Old Nov 12, 2013 | 06:54 AM
  #74
Tajohns34's Avatar
They were okay in the little bit of the snow we've had since I got it. They are however awful in the rain. Every time i go up a hill the back tires start spinning.
Old Nov 12, 2013 | 08:33 AM
  #75
Blazin00LT's Avatar
Oh yeah horrid in the rain, I could light mine up from a 25-30 mph roll. Just wait till you get one of them wet sloppy snows it becomes white knuckle fast.
Old Nov 12, 2013 | 08:41 AM
  #76
Tajohns34's Avatar
My wife's subaru has bald tires so that is top priority in tire purchases right now, then I need to fix my sagging rear leafs. Any suggestion on what I should use instead of the good years?
Old Nov 12, 2013 | 09:54 AM
  #77
BigBlackBlazer's Avatar
BigBlackBlazer is on a distinguished road
I went from the RT/S's to BFGoodrich Rugged Terrains. Great looking tire and fantastic in rain. haven't tested them in mud or snow yet.
Old Nov 13, 2013 | 12:21 PM
  #78
Blazin00LT's Avatar
I love my Cooper Discoverer A/T3s. Grip in rain, snow, dry, you name it. Now I have to be on a slick wet parking lot to get it to even spin them.
Old Nov 21, 2013 | 07:05 AM
  #79
Tajohns34's Avatar
So I decided I would to the 4 headlight "upgrade". I tried the 1 wire method. I spliced into the yellow wire from the low beam on the passenger sided and ran it to a ground. That is it. I didn't solder this or even ground it that well. This was only temporary to test it out. I want to eventually run the ground through a fuse and a switch on my dash somewhere. Here are the pics.
Attached Thumbnails 2000 Boring Blazer Build-20131120_161839_zps542afb59.jpg   2000 Boring Blazer Build-20131120_161853_zpsccc24347.jpg   2000 Boring Blazer Build-20131120_162143_zpsd72d965f.jpg   2000 Boring Blazer Build-20131120_162701_zps38e4de66.jpg
Old Nov 21, 2013 | 07:25 AM
  #80
newguy's Avatar
I don't believe you fuse the ground, only the positve
