2000 chevy blazer ls 4x4 2kdumpbox*
Old Aug 3, 2011 | 12:02 PM
racer1044's Avatar
racer1044 is on a distinguished road
To pull off the look your going for you really need to have a 2wd. there is no way to go that low with a 4wd. Ive seen a few trucks run without the torsion bars completly but I DO NOT reccomend that at all.
Old Aug 3, 2011 | 12:04 PM
TheRandom1's Avatar
Plus, by doing that you essentially have...a 2WD truck with no front springs. Easier to trade your truck for a 2WD or change the plans, really.
Old Aug 3, 2011 | 04:08 PM
Old Skool Soldier's Avatar
Old Skool Soldier is on a distinguished road
2-3-4 Lowering Kit 4x4 S10 S15 BLAZER SONOMA JIMMY S-10 | eBay
This is what you're looking for. I made a mistake, you don't need lowering shackles, its a lowering block/U bolts. Basically the blocks go between your rear diff and the leaf springs, lowering the ride hight in the rear. The Torsion keys that are supplies arn't really neccecary. Look up Lowering block s10 on Ebay, they run around 29.99. The torsion keys are located on the underside, close to where the front and rear doors meet. Look for long bars, from the front end to mid way down of the underside. You'll see a bolt sticking out on either torsion bar.
Old Aug 4, 2011 | 02:09 AM
2kdumpbox's Avatar
2kdumpbox is on a distinguished road
i see, ill try that, but at the moment i have a bigger problem, bad valve cover gaskets, leaking oil on my manifolds and almost starting my truck on fire. when i do the gaskets ill mess with the torsion bars a bit, ill throw it up on craigslist for 2500$ or trade for a short bed short cab 2wd s10.? did they even make those in a 4.3? cause i feel like a 2.2 has almost 0 *****.
Old Aug 4, 2011 | 06:27 AM
TheRandom1's Avatar
Yes, they made regular s10s with a 4.3.
Old Aug 4, 2011 | 10:59 PM
2kdumpbox's Avatar
did the valve cover gasket, works fine now, got it inspected, putting my magnaflow muffler on hopefully saturday, ordering my cai tomorrow, getting a set of these for 200$ off a friend, running 2inch wheel spacers in the rear, 1 inch in the front, how you think it will look? also have new tires if i have time im gonna try and get 2 inches of lowering out of my truck over the weekend, is that do able?
Old Aug 4, 2011 | 11:16 PM
2kdumpbox's Avatar
this is the look im going for, im trying to get a set of these also. well see how this pans out, i will keep everyone posted.
Old Aug 5, 2011 | 08:27 AM
TheRandom1's Avatar
I see the appeal of the drop (not the wheels... never liked them) but why keep the 4X4 while doing that? It'll be basically useless, even in snowy weather, the snow will stop you before not having 4X4 will.
Oh, and fixed the link for ya. From PB, use the IMG code (starts with [IMG]) or Direct Link if you're using the [IMG] box here.
Bradley2424
Mar 19, 2010 01:20 PM
crags
Nov 21, 2008 02:25 PM
crags
Nov 20, 2008 09:16 AM
COUNTRYBOY061488
Aug 28, 2008 07:54 PM
ptwarrior92
Jan 31, 2007 03:01 AM
