4.3 Vortec swap
4.3 Vortec swap
So I have a 99 Blazer LS 4.3l Vortec, I wanna do a swap but Im not sure what I wanna put in it. I found a nice 383 Stroker, but Ive heard that 350 and 305s are the most common swaps. Will a 383 fit in it? What kind of rebuilding will I be looking at? And anyone got any sites for good engines? Ive mainly been using Jegs lately. Thanks a million.
But don't mistake it for an easy swap. If you don't get the right mounts, or locate the engine at the right height or front/back location you will have major clearance problems with headers to the firewall and the oil pan to the front crossmember. Lots of people end up with the front of the engine raised up way too far in order to clear the stock oil pan, and this causes all kinds of fitment issues elsewhere. The proper solution is an aftermarket oil pan - they make them for S10/Blazer V8 swaps.
I have a 383 in a 2WD 1989 S10 with a carburetor. 4WDs and second generation vehicles have additional issues as well as different sets of issues. In any case you can buy a brand new Vortec 350 crate engine from JEGS, however you will however need a donor pickup for the rest of the needed parts.
Another option is the LS engines like the 5.3. Someone on this site did one and had a good writeup in the "builds".
