85 S10 Blazer revival
Old Feb 26, 2010 | 06:14 PM
Spectreblazer's Avatar
Banned
Spectreblazer is on a distinguished road
Originally Posted by 04CVLXsport
If the booster is bad , then that would be a vacuum leak and be causing your high idle.
might also solve your brake problem
bad booster=crappy brakes
Old Feb 26, 2010 | 10:35 PM
abig84's Avatar
lol.. those stupid wheel cylinder clips. wow i havent done one of those in a while. i pray i never have to do one ever again. i forgot all about them things
Old Feb 27, 2010 | 01:32 AM
Gimpy Blazer's Avatar
Gimpy Blazer is on a distinguished road
Did you bench bleed the master cylinder before you installed it? Makes a whole lot of difference.
Got an 84 Jimmy that I've been putting off getting up to speed again. You have given me incentive though. Thanks.
Old Feb 27, 2010 | 08:07 AM
edumspeed's Avatar
edumspeed is on a distinguished road
Thanks guys Yes, the master cyl. was bench bled before installing it, also the four wheels individually were bled. I may replace the calipers too, just in case. After all, brakes are one of the most important system on any vehicle. That way it will have all the brake system overhauled.
Old Dec 27, 2010 | 07:54 PM
edumspeed's Avatar
Default Update
After many months of other stuff getting in the way, I decided to take another look at the truck. My best friend scored a cheap parts car to fix his Malibu and he handed me the working brake booster the parts car had. So today I decided to remove the one in the Blazer. After separating the master cylinder from the booster, i noticed some humidity. I cleaned it with a dry rag and replaced everything back and pumped the brake pedal w the engine running. I separated the thing again and my suspicion was correct, the new master cylinder has a leak. I removed the brake booster anyway to take a closer look. I put them side to side for comparison, and I have a problem. The pedal push rod on the truck is longer than the other and I don't have the slightest idea of how to remove it and replace it to the other booster. Has anyone done it?
Old Aug 18, 2013 | 02:23 PM
edumspeed's Avatar
Selling the truck. No use letting it keep rusting away in the back yard.
Dallas1970
Feb 22, 2019 05:05 PM
94BlazerGirl
Aug 28, 2014 06:14 PM
rfine67
Aug 13, 2011 01:04 PM
wlorton
Oct 17, 2010 06:23 PM
ricky
Jul 22, 2010 08:04 PM
