95 Junkyard Jimmy
Old Jun 23, 2019 | 07:54 AM
SRIslash's Avatar
SRIslash is on a distinguished road
Nice work, I have a 96 and a 98.
the airbox on them could certainly use some help. It just blankly pulls air from behind headlight.
Old Jun 26, 2019 | 03:35 PM
Pat8987's Avatar
Pat8987 is on a distinguished road
Thanks man!
The more I look at it the more I think I'm gonna just snorkle it
Old Jun 26, 2019 | 04:45 PM
Pat8987's Avatar
Tonight i probably will take out the spark plugs and do a compression check. If something doesn't look right I will take the heads off and redo the headgasket while I'm there. I need to get another LIM gasket so I'll just get the set this time incase compression is bad
Old Jul 13, 2019 | 12:01 AM
Pat8987's Avatar
Did a compression test. Plugs looks like I have a spark problem. I changed the spark plug wires to NGK ones and also noticed one of the dist screws was hardly in and the cover was able to move... Hope that will fix that
Compression was alright. Between 140-150. I missed middle cylinder on the driver side as it was blocked by steering shaft.
I had decided to get a jeep steering shaft and will check the last cylinder while I swap them.
Last thing I need to fix is the brake line to front passenger wheel, it's leaking somewhere. So grabbed a replacement while I went to get the steering shaft.
Things are looking up again! I need to find some 17s and I got a hook up on some tires
Pat8987
Mar 18, 2019 09:10 AM
John Libbey
Jun 9, 2018 09:15 PM
95BlazenLT
Sep 17, 2012 03:27 PM
Dadatone
Jul 2, 2012 08:36 PM
autogeek13
Mar 16, 2010 02:13 PM
