97 blazer build
Old Nov 27, 2010 | 02:44 PM
  #21
blkfloyd's Avatar
blkfloyd is on a distinguished road
ok i got the front drive shaft out and the encoder motor off the transfer case i will take some pics later of all the steps but i did have one question when the front of the driveshaft came loose the lil caps came off is that a problem?
Old Nov 27, 2010 | 02:54 PM
  #22
blkfloyd's Avatar
starting from left to right picture #1 we have the transfer case shift shaft (top) and the transfer case drive shaft gear (bottom) when prying the driveshaft away from this gear pry in between the transfer case and drive shaft shield
picture #2 is of the transfer case side of the driveshaft! This is a clear picture of the shield that slides on to the case.
picture #3 is of the yoke on the front differential notice the 4 bolts on the yoke which hold brackets clamping the yoke to the driveshaft
these bolts are size 11mm and can be a pain to break loose in that case just use some good pb blast. worked for me. now when you remove the 4 bolts take a pry bar and pry the drive shaft loose do this best way you know how i got mine out after trying several different angles and positions it finally broke loose!
picture #4 is kind of a crappy pic of the front side of the drive shaft
after you get the drive shaft off then you can remove the encoder motor
Attached Thumbnails 97 blazer build-1127001542.jpg   97 blazer build-1127001543.jpg   97 blazer build-1127001543a.jpg   97 blazer build-1127001543b.jpg
Old Nov 27, 2010 | 05:47 PM
  #23
blkfloyd's Avatar
these are pictures of the encoder motor that controls shift........... notice the three bolt holes these are 10mm bolts once those are out just wiggle it off and unplug it and your set (some people say that this can be done without removing the drive shaft but i found it easier to remove the drive shaft first)
Attached Thumbnails 97 blazer build-1127001507b.jpg   97 blazer build-1127001507a.jpg
Old Nov 29, 2010 | 09:15 AM
  #24
blkfloyd's Avatar
ok i have decided to use something similar to a battery terminal to turn the shaft however since battery terminals are made of such cheap metal then i will have to use something similar but stronger i figure it will tighten around the shift shaft and be strong enough to turn the shaft then i decided on using a threaded rod welded to it. Anybody know of something similar to a battery terminal that i could use?
Old Nov 29, 2010 | 03:25 PM
  #25
Steinbruchsoldat's Avatar
Steinbruchsoldat is on a distinguished road
Just take the encoder motor apart and use the oem lever that's inside. Thats how i did mine because it's really easy...
Old Nov 30, 2010 | 07:42 AM
  #26
blkfloyd's Avatar
thanks i would do that however i want to save the current encoder motor,tccm,and 4x4 switch because my gf's sister has a blazer and wants her 4x4 fixed b4 the snow hits so im saving the parts that i know or think are good and maybe it will solve her problem i offered to do a manual conversion however she likes the push button system and does not want a conversion! Well the situation on my blazer is this i am running a lil over budget and wanted to re-do the interior so im gonna try to clean out my turn signal/multifunction switch instead of replacing new to save money. There is a tutorial here that tells how to do that and a few other things
http://www.automotiveforums.com/vbul...d.php?t=577320
Wish me luck guys also nobody answered my question about the driveshaft caps
Old Nov 30, 2010 | 07:46 AM
  #27
You would likely get better responses to your questions if you were to ask them in the appropriate technical section. Just sayin'. The Builds section is to chronicle your progress on your truck and people come in here just to read about and look at peoples rides for ideas, etc.
Old Nov 30, 2010 | 12:37 PM
  #28
blkfloyd's Avatar
thanks swart,
understood just didnt wanna scatter my questions everywhere but will do that from now on
UPDATE: fixed the turn signal switch problem by cleaning the switch and saved money thats awesome
Old Nov 30, 2010 | 12:48 PM
  #29
It's more about house keeping than anything else. No worries.
Old Dec 1, 2010 | 05:03 AM
  #30
blkfloyd's Avatar
gonna clean up the interior and order the seat paint today
http://www.youtube.com/watch?v=K9sgJT12cNk
this stuff looks awesome its a type of spray fabric dye that dry's soft its called simply spray fabric paint
ill let you know how it goes
