98 blazer offroad/dd build aka Sally May
Old Feb 15, 2015 | 09:15 PM
  #21
Carrico4's Avatar
Carrico4 is on a distinguished road
I say dont spend money on wheels because youre going SFA unless you plan on dana 30/8.8 and wheel adaptors, but if you dont plan on those axles, i say dont waste the money.
Old Feb 17, 2015 | 12:51 PM
  #22
abig84's Avatar
Like Kyle said the astro box will be the better way to go with soa. I have an astro box with a flat pitman and my drag link and tie rod are almost parallel. I have no bump steer at all with my setup.
mine looks pretty much the same way. i used the factory astro van pitman arm and just had it machined to fit the tie rod ends i was using.
i used to run 33 12.50 all terrains on a stock s10 set up and the cv joints just wont hold up. everytime i had to turn the wheel more then like 180 degrees they would grenade.
now my s10 has 10bolt chevy axles, welded rear axle and 33 14.00 boggers and still using the same axles with no breakage. just normal wear and tear
if you want to daily drive and occasionally offroad that thing maybe a body lift and some skinny 31s
Old Mar 7, 2015 | 11:05 PM
  #23
justice4x4's Avatar
justice4x4 is on a distinguished road
Sorry I haven't posted in awhile. Work has been crazy and I'm only home on the weekends. But I did get my d44s from a 97 rodeo and a 87 grand waggy. My uncle has the axles right now and he is gonna paint, and rebuild them for me. I got the parts order for the axles too.
I'm goin with
Motive Gear Axle shafts
Yukon Gear 4.30 ring and pinion
Detroit Lockers
Old Apr 16, 2015 | 12:13 AM
  #24
justice4x4's Avatar
I know I haven't been on for awhile but I've been dealing with stuff with some family stuff. But good news is that the axles are done and painted. But I'm not gonna do the swap just yet cause I don't have another vehicle to drive while the blazer will be down. I haven't done much to the blazer other then put led lights in my domes and map lights.
To do list for this summer
Finish LEDs inside
Fix my 4wd
Redo my stereo system
Fix my radio antenna
Put a new grille in
Old May 31, 2015 | 12:46 AM
  #25
justice4x4's Avatar
Sorry that I haven't updated for awhile. Im not doing SFA anymore cause my sister is going to be using my blazer and she won't be able to get in it. I'm keeping the axles tho for a future project. I'm going to build a slightly lifted daily on 31s the I can take through the easy trails at my buddy's farm and the offroad park near me.
I figured I'd make a new to do list.
To do
Led interior lights
Pumpkin 6.2 double din hu
Alpine type r 10" sub (not sure on amp)
New grille, bumper, valance fenders and hood
Fix rust
Zr2 axle and iron diff with 3.73 gears
Manual 4wd (almost done)
New wheels (not sure what kind)
Tint
Exhaust
Change shackles
Body lift
Led light bar
Already done
Crank tbars and shackles
Tb mod
Quad beam mod
Old Jun 2, 2015 | 01:23 AM
  #26
justice4x4's Avatar
Some pics
Did some flexin on an old ramp at my parents house.
Some inside pics. Yes I know I need to clean it! It sucks working for a logging company I can never keep the floorboards clean.
I got off work last night and when I was backing up I didn't see a stump and bam.
Attached Thumbnails 98 blazer offroad/dd build aka Sally May-img_20150601_132537676_zpsxq7acjhn.jpg   98 blazer offroad/dd build aka Sally May-img_20150601_132601425_hdr_zpslflvaxok.jpg   98 blazer offroad/dd build aka Sally May-img_20150601_142259458_hdr_zpsbcpcwpyk.jpg   98 blazer offroad/dd build aka Sally May-img_20150601_142310797_hdr_zpsj6lwlhfj.jpg   98 blazer offroad/dd build aka Sally May-img_20150601_142240917_zps7xlmtm25.jpg
Old Jun 19, 2015 | 12:56 PM
  #27
justice4x4's Avatar
Finally an update. I got me zr5 wheels from my boss today. I'm gonna sand them done and repaint them. The paint is flaked off bad around the edges. Ill post pics soon.
Old Jun 23, 2015 | 12:52 PM
  #28
justice4x4's Avatar
Attached Thumbnails 98 blazer offroad/dd build aka Sally May-img_20150619_172702609_zpscsew9ily.jpg   98 blazer offroad/dd build aka Sally May-img_20150618_160205781_zpsauflfwrb.jpg   98 blazer offroad/dd build aka Sally May-img_20150618_155049812_zpsobuzwsjf.jpg
Old Jun 24, 2015 | 07:40 AM
  #29
ZachC540's Avatar
ZachC540 is on a distinguished road
If you're still wanting to make bumpers you can check out my build thread for a very simple front bumper design. It's held up very well for me so far. https://blazerforum.com/forum/builds...r-build-80458/
Old Jun 24, 2015 | 12:45 PM
  #30
justice4x4's Avatar
Thanks Zach. I'm not sure if I wanna build bumpers now or not. My build took a different direction. I'll keep it in mind though.
I picked me some bravada hvca ***** and grand Prix gauge needles today at work hopefully I get them on this weekend.
