99 blazer posi 8.5 inch rear diff and says 3.42 gears
Old Mar 20, 2018 | 02:06 PM
Daisy Hebert's Avatar
Daisy Hebert is on a distinguished road
Default carrier bearings
The carrier bearings are the ones that hold the axle shafts once they slide in correct?
Old Mar 20, 2018 | 04:42 PM
2004 Blazer's Avatar
2004 Blazer is on a distinguished road
"very carefully used my impact gun to slowly tighten the crush sleeve" I did the same thing on a '77 10 bolt rear I used a tire spoon through the yoke indexed the pinion nut and just turned up the air pressure gradually to get the right preload.
Old Mar 24, 2018 | 01:17 AM
ChuckNTruck's Avatar
Please for your safety, use self tapping screws or nuts and bolts to reattach that airbag sensor to the core support and disconnect the battery when working with anything in the airbag system.
Those are the sensors that sense the impact in a crash and are used in conjunction with the airbag module to deploy the airbags themselves.
If one of those sensors are damaged and the module itself gets impacted the airbags will deploy.
I have accidentally done this when i tried to remove an airbag module from a wrecked car with an impact gun. It scared the hell out of me when they went off.
Old Mar 24, 2018 | 02:06 AM
No. the carrier bearing supports the ring & pinion carrier assembly. The axles are supported by the Splined input in the carrier assembly & axle bearings on the outer ends of the axle tubes
Old Mar 27, 2018 | 04:04 PM
chevyriders's Avatar
THIS! Please heed that advice
98BlazerBadass
Tires and Wheels
Nov 17, 2016 04:23 AM
James1965
Jan 16, 2012 11:32 AM
JetJock79
13
Sep 16, 2011 02:32 PM
Keeler
Lifting Tech
22
May 29, 2010 03:53 AM
