99 Jimmy 1 ton build
Old Nov 2, 2010 | 07:47 PM
SgtJimmy's Avatar
SgtJimmy is on a distinguished road
Default 99 Jimmy 1 ton build
Joined a few months ago , posted a few pics and have been getting a lot of requests for build info. so I figured I would post a build thread.
here is what i started with :
bone stock 99 Jimmy 2 dr with 150k
I had a set of 1 ton Axles from a 98 Dodge just taking up space. so......
I decided they would go great under the Jimmy , so the cutting began
Rear was first , because it was much easier .... Stock springs with a couple of leafs added , SOA.
On to the front , homemade cross member , Dakota leafs SOA. Axle set 2" foward , Astro van gear box and TJ drop pitman arm. 1.5 DOM steering with 7/8 heims
Old Nov 2, 2010 | 07:58 PM
SgtJimmy's Avatar
Picked up a set of Military H1's with 37" Goodyears, recentered the H1's to 3"back space with Copperhead Fab centers:
Custom built front bumper all made from 3/16th plate
Ended up with this :
First trip out in the woods and I popped the motor
So out with the old and in with the new ......
While it was down for the motor swap I went ahead and pulled the trans and transfer case . Had the 4l60e rebuilt with all the goodies and swapped out the 236 for a 213c manual shift from a 93 s-15.
I made up some rock rails and swapped the 37's for 39.5's
Old Nov 2, 2010 | 08:26 PM
mov4x4's Avatar
mov4x4 is on a distinguished road
That is BEAST!!! What transfer case did you have to end up useing?
Old Nov 2, 2010 | 09:38 PM
SgtJimmy's Avatar
I used a 231c out of a 93 S-15 , I still need to put another tone ring on the output shaft so it will shift gears in 4lo but I'll get to that later.
Old Nov 2, 2010 | 11:20 PM
DKSDAD's Avatar
One word, COOL!!!
Old Nov 3, 2010 | 12:05 AM
mov4x4's Avatar
Ok I'm not use to the numbers because I've never had to do anything big to my t-case
Old Nov 3, 2010 | 11:16 AM
dougg01's Avatar
dougg01 is on a distinguished road
Seen most of this on the C.O.R.E. website. Coolness. Best story was trying it out with the welds only tacked and it falling down.
Old Nov 3, 2010 | 03:47 PM
SgtJimmy's Avatar
Hahahah ! sometimes I do so really stupid things .
Old Nov 3, 2010 | 04:54 PM
PaulO2288's Avatar
PaulO2288 is on a distinguished road
Freaking AWESOME!!! What gears are you running? And another 4.3?
Old Nov 3, 2010 | 06:32 PM
SgtJimmy's Avatar
Thanks .
I'm running 4.10's for now ( sucks but .... )
I went with another 4.3
