99 Jimmy 4 door 4x4 SLT
Old Dec 29, 2014 | 10:30 PM
  #31
bigpeet's Avatar
bigpeet is on a distinguished road
Santa brought me two sets of these:
Got the front set in this afternoon. They sound so much better. My rear door speakers aren't working right now, so I plan to figure out why not when I install the rear set.
Attached Thumbnails 99 Jimmy 4 door 4x4 SLT-2014-12-29201539small_zps54562783.jpg
Old Dec 30, 2014 | 06:27 AM
  #32
Tajohns34's Avatar
For some reason the rear speakers in blazers & jimmys always die. Mine were dead when I got my blazer. It most likely isn't your wiring. I would bet anything that your speakers are just dead.
Old Dec 30, 2014 | 11:00 AM
  #33
jbrooks19's Avatar
jbrooks19 is on a distinguished road
I switched from the stock speakers to all Rockford Fosgates and WOW, what a difference.
Old Jan 7, 2015 | 06:49 PM
  #34
bigpeet's Avatar
The weather has been bad, so haven't gotten the rear speakers installed yet. I have no doubt it will be a huge improvement, though.
Thought about adding this:
New Alternator High Output 220 Amp For 4.3L Chevy S10 Blazer 98 99 00 & Gmc Jimmy:Amazon:Automotive
Anyone know anything good or bad about that brand/model?
Old Jan 7, 2015 | 09:48 PM
  #35
maroon96blazer's Avatar
maroon96blazer is on a distinguished road
search for those on the forum they aren't very good the remans you buy are worthless i went threw 3 till i got the ad244 upgrade made one hell of a difference. good looking build so far
Old Jan 11, 2015 | 05:24 PM
  #36
bigpeet's Avatar
Got my rear speakers installed this afternoon and they sound great! Huge difference. The factory ones were just dead as Tajohns34 had suggested.
In addition, I ordered my next mod, should be here before next weekend... :-)
Old Jan 11, 2015 | 05:25 PM
  #37
bigpeet's Avatar
Also hoping to track down an AD244 for a decent price soon.
Old Jan 12, 2015 | 12:28 PM
  #38
Tajohns34's Avatar
You can also use a DR44G.
Old Jan 15, 2015 | 12:11 AM
  #39
bigpeet's Avatar
Here is my next upgrade:
It was delivered today, but because of the sleet, I decided to wait to install it.
Attached Thumbnails 99 Jimmy 4 door 4x4 SLT-2015-01-14195410small_zpsf8c56e61.jpg   99 Jimmy 4 door 4x4 SLT-2015-01-14195806small_zpsba208971.jpg
Old Jan 17, 2015 | 06:33 PM
  #40
bigpeet's Avatar
The weather was great today, so I got this junk ripped out:
Here it is with all the stock stuff removed:
Installed the heat shield:
However I drilled the top hole too large. Luckily I has a sheet metal screw that was the size of the hole I drilled. Also, as you can see from this picture, there was no way my drill was going to be able to fit in that tight space to drill the bottom hole. It seems secure without it, though, so I didn't worry about it.
Installed the intake plenum:
Got everything else hooked up:
The instructions say not to let the intake be in contact with any other part of the vehicle, but I found that to be impossible. It's a pretty tight fit. I don't know if there is a minimum clearance for the filter, but it's pretty close to something on all sides. There's a little space, so that may be fine. I just don't have any first-hand experience to know for sure.
Also, I took it for a very short test drive and found the throttle would stick a little in the closed position. I backed off the intake plenum mounting bolts about a half turn and that seemed to take care of it. I'm hoping to test it a little more tonight of tomorrow to get the full effect.
Attached Thumbnails 99 Jimmy 4 door 4x4 SLT-2015-01-17130608_zps86e61940.jpg   99 Jimmy 4 door 4x4 SLT-2015-01-17145954_zpsec6c886d.jpg   99 Jimmy 4 door 4x4 SLT-2015-01-17150003_zps04c5164c.jpg   99 Jimmy 4 door 4x4 SLT-2015-01-17150440_zpsb52d5e98.jpg   99 Jimmy 4 door 4x4 SLT-2015-01-17150505_zps514d673a.jpg
