-   Builds (https://blazerforum.com/forum/builds-48/)
-   -   Altoncustomtech's 1998 Chevy Vldenture (https://blazerforum.com/forum/builds-48/altoncustomtechs-1998-chevy-vldenture-50155/)
altoncustomtech Oct 12, 2010 10:07 PM
I take the words "Open to all Projects" literally, so I'm going to go ahead and post the build I did for my wife's van up for everyone to see. If it's a crime against nature to put the van on the site, then by all means accept my apology for the assumption ahead of time and feel free to delete it, lol.
My wife and I have owned this van going on about 7 years now. It's been a great daily driver and hasn't given too many real problems. It's been through 3 prior builds before this one, although this one is easily the most powerful and expensive yet. The headunit is a Kenwood KDC-X991, component sets are Hifonics Atlas 6.5's. Laugh if you must, but I would put the set up against most sets under the $500 mark any time. I've had my fair share of speakers and these sound the best to us, especially for the measly $120 ea. set we paid. They are mounted in custom build MDF baffles along with a bandwagon's worth of sound deadener. I give that info up front as this build/rebuild did not include any changes to the HU or components. The last build had Hifonics subs and amps, both of which I was sorry I had purchased and as soon as it started going bad, I began to purchase much better replacements. When the subs went bad I purchased a pair of 12" Fi Q subwoofers. For anyone who doesn't know Fi, please visit the website at www.ficaraudio.com. You'll find some of the nicest, american built, made to order subwoofers available. The only ones available in such a matter as far as I know. The Hifionics amplifiers were replaced, thanks to some luck, with Sundown Audio amps. An SAX-100.4 now powers the component sets and an SAZ-2000D is powering the Q's. The van is equipped with a DC Power 230 amp alternator as well as a C&D Dynasty High Rate 75ah secondary battery in the rear with the amps, behind the amp rack.
Enough with the descriptions, let the photo's begin. Hope you guys enjoy the build as much as I did building it.
First thing I did was build then enclosure. 4.2cuft net tuned to 32hz with a plexi window.
http://i889.photobucket.com/albums/a...N/DSCN0221.jpg
http://i889.photobucket.com/albums/a...N/DSCN0222.jpg
http://i889.photobucket.com/albums/a...N/DSCN0227.jpg
My son helping with the project.
http://i889.photobucket.com/albums/a...N/DSCN0226.jpg
http://i889.photobucket.com/albums/a...N/DSCN0229.jpg
http://i889.photobucket.com/albums/a...N/DSCN0230.jpg
http://i889.photobucket.com/albums/a...N/DSCN0231.jpg
http://i889.photobucket.com/albums/a...N/DSCN0232.jpg
http://i889.photobucket.com/albums/a...N/DSCN0233.jpg
Some pics of the amps and subs that are in this build.
http://i889.photobucket.com/albums/a...0220001128.jpg
http://i889.photobucket.com/albums/a...0220001130.jpg
http://i889.photobucket.com/albums/a...0220001131.jpg
http://i889.photobucket.com/albums/a...220001131a.jpg
altoncustomtech Oct 12, 2010 10:17 PM
The pictures of everything between the box done being built and me beginning to prime it are lost. So sorry for the jump through time here.
http://i889.photobucket.com/albums/a...0729000713.jpg
http://i889.photobucket.com/albums/a...0729000714.jpg
http://i889.photobucket.com/albums/a...729000714a.jpg
http://i889.photobucket.com/albums/a...729000714b.jpg
http://i889.photobucket.com/albums/a...729000714c.jpg
http://i889.photobucket.com/albums/a...0730000713.jpg
http://i889.photobucket.com/albums/a...730000713a.jpg
Now I'm putting the color on. Found out the hard way it's not a good idea to paint in high heat and humidity. Anyone familiar with paint and body work knows of "blushing". I discovered what it was and the pain that it is first hand this summer.
http://i889.photobucket.com/albums/a...01001129-1.jpg
http://i889.photobucket.com/albums/a...04000723-1.jpg
http://i889.photobucket.com/albums/a...0805001948.jpg
Clear helped "wetten" up the look of the paint which helped with the "blushing".
http://i889.photobucket.com/albums/a...0808001225.jpg
http://i889.photobucket.com/albums/a...0808002255.jpg
http://i889.photobucket.com/albums/a...0808002300.jpg
Voila, finished enclosure. Or nearly so, have lots of clear overspray dust to clean up out of the inside. (the white stuff on the bottom)
http://i889.photobucket.com/albums/a...0808002308.jpg
wlorton Oct 12, 2010 10:22 PM
That is a good looking box....
altoncustomtech Oct 12, 2010 10:28 PM
Now I begin on the amp rack. With such a large enclosure I had to find a different place to mount the new amps. I found a good place for them and went with it.
http://i889.photobucket.com/albums/a...0807001313.jpg
http://i889.photobucket.com/albums/a...0807001319.jpg
Had to create a template, piece by piece for a beauty panel to flush the rack board to the wall of the van.
http://i889.photobucket.com/albums/a...0808001200.jpg
http://i889.photobucket.com/albums/a...808001200a.jpg
If you notice the rounded corners, the 1/4" ply couldn't make the bends so I had to improvise. The routing in the center of the board is for the 4 gauge power wires and the speaker wires for the 4 channel amp. It's so that the wire's will be recessed into the board and not keeping the board from sitting all the way up against the wall of the van where the rear wheel well is. Along with the holes drilled for the wires to make the connections to the amps.
http://i889.photobucket.com/albums/a...0811002045.jpg
http://i889.photobucket.com/albums/a...811002045a.jpg
http://i889.photobucket.com/albums/a...0811002018.jpg
Carpet on the amp rack board.
http://i889.photobucket.com/albums/a...0811002108.jpg
http://i889.photobucket.com/albums/a...0815002335.jpg
http://i889.photobucket.com/albums/a...0813001518.jpg
The amps mounted now.
http://i889.photobucket.com/albums/a...0815002345.jpg
http://i889.photobucket.com/albums/a...0815002350.jpg
http://i889.photobucket.com/albums/a...815002350b.jpg
http://i889.photobucket.com/albums/a...815002350c.jpg
http://i889.photobucket.com/albums/a...815002350a.jpg
altoncustomtech Oct 12, 2010 10:36 PM
On to the installation of the subs into the enclosure.
Didn't somebody say, curiosity deafens the cat? lol
http://i889.photobucket.com/albums/a...0813001709.jpg
http://i889.photobucket.com/albums/a...0813001711.jpg
Okay, getting serious now.
http://i889.photobucket.com/albums/a...0814001110.jpg
http://i889.photobucket.com/albums/a...0814001650.jpg
I use Neutrik Speak-on connectors as they make it very easy to unhook the subs for removal without having to worry about shorting anything or fraying wires. They also look very nice when finished. Knukonceptz Karma speaker wire makes the used of them very nice as well with the jacket they use.
Soldering the wires to the terminals.
http://i889.photobucket.com/albums/a...0814002120.jpg
http://i889.photobucket.com/albums/a...0814002121.jpg
http://i889.photobucket.com/albums/a...0814002123.jpg
http://i889.photobucket.com/albums/a...0814002124.jpg
Now to show the finished sub installation into the enclosure.
http://i889.photobucket.com/albums/a...0814002148.jpg
http://i889.photobucket.com/albums/a...0814002149.jpg
http://i889.photobucket.com/albums/a...814002149a.jpg
http://i889.photobucket.com/albums/a...0814002207.jpg
http://i889.photobucket.com/albums/a...814002207a.jpg
http://i889.photobucket.com/albums/a...814002207b.jpg
http://i889.photobucket.com/albums/a...814002207c.jpg
altoncustomtech Oct 12, 2010 10:45 PM
And now for the finished product. Again, I'm sorry I don't have the complete installation sequence. At the time I finished this, my wife was in the hospital with stomach trouble. I was staying at the house in the evenings and nights so I could take care of the kids and get them on the bus in the morning before heading back to be with my wife in the hospital. I couldn't sleep so I worked on the van and completed it. I didn't think about taking any pictures until it dawned on me I hadn't taken a single one after installing everything and mounting the amp rack. So I took a few on what remained.
If you notice, the middle seat belt and the cup holder are still in place as well. :D
http://i889.photobucket.com/albums/a...0824000015.jpg
http://i889.photobucket.com/albums/a...0824000024.jpg
http://i889.photobucket.com/albums/a...824000024a.jpg
http://i889.photobucket.com/albums/a...824000024b.jpg
http://i889.photobucket.com/albums/a...0824000056.jpg
http://i889.photobucket.com/albums/a...0824000057.jpg
Here's the next morning with everything installed, tuned and tested.
http://i889.photobucket.com/albums/a...0824001546.jpg
http://i889.photobucket.com/albums/a...824001546a.jpg
http://i889.photobucket.com/albums/a...0824001547.jpg
http://i889.photobucket.com/albums/a...824001547a.jpg
And there it is. The Fi Q's are easily the most smooth, authoritative and best overall sounding subs I've ever had the pleasure of owning. The Sundown amps are great performing piece's of equipment, well worth their modest price. Thanks for taking a look. I thought it would be a good thing to share my interests with everyone. Hopefully the Jimmy will be getting it's own work done very soon.
DKSDAD Oct 12, 2010 10:58 PM
I guess you are booming with the trunk of funk? By the way I hope your wife feels better.
wlorton Oct 12, 2010 10:59 PM
Its awesome!
altoncustomtech Oct 12, 2010 11:03 PM
Thank you. The way the paint turned out still bother's me. An unfortunate side effect of my Type A personality, lol.
As I stated in my introduction, most of what I do is audio related. So yeah, the wife booms the funk to no end, lol. Yes, she's doing much better since then. I brought her home from the hospital later the same day the last pictures were taken. It brightened her day to see it done.
altoncustomtech Oct 12, 2010 11:04 PM
Originally Posted by wlorton (Post 370320)
Its awesome!
lol, Thanks!!
