Baby Semi Build
Old Sep 6, 2012 | 07:13 AM
  #261
TheRandom1's Avatar
May want to toss some touch up paint on the screw heads as well, but otherwise it looks pretty darn good!
Old Sep 6, 2012 | 09:42 AM
  #262
rexmburns's Avatar
Super Moderator
Looks good man very creative with the cover I like it!!
Old Sep 6, 2012 | 08:39 PM
  #263
xgiovannix12's Avatar
Thanks guys
The screws are black it was the flash from the camera .. On an other note.. I got the new vac switch connecter Thanks to okiedoak20.
Im hopefully going to install it tomorrow.
Old Sep 7, 2012 | 01:25 PM
  #264
richphotos's Avatar
good stuff brother
Old Sep 16, 2012 | 07:25 PM
  #265
Installed the Vac switch connector. I also installed the switch for the vacuume solenoid when I get it for my Front end lock.
I plan to also install one of those Power blocks Since I have to many connections on the POS terminal on the battery.
On an other note My transfer case is still leaking from the vac switch. IT must be loose. I think ill check it tomorrow. BTW it only leaks when the 4x4s engaged.
Once i get this leak solved ill install my skid plate again.
Edit: Forgot to mention that the amber switch is for my rear work lights and the red one is for my Front end lock.
Old Sep 16, 2012 | 07:53 PM
  #266
trobbins's Avatar
where i live i have a bunch of those old hot rods come into my work which is a gas station an alot of them have side pipes an there all the same then today i had a 76 stingray come in an the side pipes were litterally molded into the body an just not on the side of the car an it looks so much better then every other hot rod out there so if do side pipes look into molding them into the body
Old Sep 16, 2012 | 08:32 PM
  #267
richphotos's Avatar
I'm confused.
Old Sep 16, 2012 | 08:50 PM
  #268
Same Richie.
Old Sep 16, 2012 | 09:36 PM
  #269
chris015's Avatar
and thats how you install the governor. 3/4 wrench torqued to 400ft/lb
did i confuse you even more? LOL. John,do you have any links to a decent but cheap fuse block? I cant find anything for less then $40 bucks.
Old Sep 16, 2012 | 10:14 PM
  #270
Not to an fuse block but to a power block I do. Just need to add inline fuses if needed.
Edit: Actually just found this one CHRIS http://www.ebay.com/itm/6-CIRCUIT-AT...bcd8ca&vxp=mtr
