Baby Semi Build
Old Sep 25, 2012 | 01:37 PM
  #291
xgiovannix12's Avatar
Nope it does not ground. And the rubber hose on top is so I dont bang into it and short any thing out.
Old Sep 25, 2012 | 01:39 PM
  #292
TheRandom1's Avatar
How is it mounted? Are you sure it isn't grounded to the chassis somehow? That would totally explain why it worked before you installed it, but now doesn't.
Old Sep 25, 2012 | 01:45 PM
  #293
nope the base is all plastic. You basically feed 12 volts on the 1st terminal and the other 5 will be powered with the 1st one. When I tested it all i did was connect the charger to the 1st pin and tested every pin with the meter. I had 12 volts to each pin.
OE Ford Motorcraft DY86 Terminal Ground Junction Block Assembly | eBay
I had this issue when I played with it and now its giving me the issue again.
Old Sep 25, 2012 | 05:11 PM
  #294
Thogert's Avatar
Have you tried moving the point that energizes the block? Since they are all connected internally, you should be able to use any terminal to energize the others, right?
Old Sep 25, 2012 | 05:21 PM
  #295
yep Ive tried switching spots for feeds.
Old Sep 25, 2012 | 05:24 PM
  #296
Thogert's Avatar
And only one works still?
Old Sep 25, 2012 | 05:35 PM
  #297
Yep I checked the resistance between all of them Non of them give me a beep meaning no connection between them. Its really weird. I had it working before I installed it on the truck. Im guessing it screwed up again after moving it.
Old Oct 10, 2012 | 07:11 PM
  #298
SOO I did a heater core job recently... I got caught up on bills and ordered some goodies for the blazer.
I ordered an fuel pressure gauge.... Im lacking power and I have a feeling my spiders leaking for some reason.
Actron Fuel Pressure Test Kit CP7818 Schrader Valves | eBay
I also ordered Some lights and a new junction block
Brass Post Stud Terminal/Junction Block 6-Position #256 | eBay
(2) LED Light 1x4.0 Surface mount with base AMBER Clearance Side Marker trailer | eBay
And finally 2 prebent body panels for my quarter panel. I have 2 small rust holes that need to be repaired.
On an other note Im happy. it feels good to be all caught up and all. I just wish i had a few weeks of warm weather now.
I also getting an new radio tomorrow. Richphotos has sent me an improved stock unit better then mine of course. Im going to be retrofitting an 1/8 stereo jack into it so I can hook up my touch.
Old Oct 11, 2012 | 07:09 AM
  #299
TheRandom1's Avatar
Nice, glad to see you're doing a little better buddy!
Old Oct 11, 2012 | 01:47 PM
  #300
Well I got the radio today. BUT I have 2 issues.... I need an adapter wire harness and I can mod an aux port on to it.... UNLESS I find an other DIY to do so.
its a sweet radio tho. =D The top one is my original.
