Blaz's 05 blazer
Old 05-14-2014 | 04:12 PM
blaz's Avatar
blaz is on a distinguished road
Made a skid plate because the stock Alum. one was bending. 3/16" plate and some cutting and welding.
Attached Thumbnails Blaz's 05 blazer-img-20140514-01023_zps4c58cb83.jpg   Blaz's 05 blazer-img-20140514-01025_zpsc9366443.jpg   Blaz's 05 blazer-img-20140514-01027_zps94a2fd9a.jpg   Blaz's 05 blazer-img-20140514-01024_zpsbdba74f9.jpg   Blaz's 05 blazer-img-20140514-01030_zpsd2b0bb2d.jpg
  #112
Old 05-15-2014 | 10:53 AM
El_Beautor's Avatar
Well that beasty should take a serious beating. And lower your center of gravity. Nice work!
  #113
Old 05-15-2014 | 11:17 AM
newguy's Avatar
Think it will affect engine running temp?
  #114
Old 05-15-2014 | 10:23 PM
blaz's Avatar
It is very similar to the factor alum. skid so I should be fine. Also, the temperature hasn't gone above 20 C (68 F) yet this year here so right now I am not worried about that. .
  #115
Old 06-26-2014 | 06:14 PM
420Blazin4X4's Avatar
420Blazin4X4 is on a distinguished road
Just wondering are you using wheel spacers on the rear of your ride with the irocs? If so are they 1.25 or 1.5? Is that 1.25 or 1.5 on each side? Appreciate any help you can give man.
  #116
Old 06-27-2014 | 07:54 AM
Tajohns34's Avatar
I have IROCs and I use 1.5" spacers on the rear of mine. Without the spacers they actually sit flush with the fenders, I just wanted them to match the front.
  #117
Old 06-27-2014 | 12:26 PM
blaz's Avatar
I am running 1.5" hub centric spacers on the rear. I think they look perfect. A ZR2 rear axle would eliminate the need for spacers.
  #118
Old 07-09-2014 | 01:46 AM
blaz's Avatar
The rough country 2.5 " lift on my blazer caused me multiple issues. Time for an upgrade.
The plan;
High pinion Dana 30 from an xj. Spring under with 4 " waggy softride springs.
Stock 8.6 " rear 10 bolt. With spring over lift.
4.56 gears and 35s KM2's.
233 t case with the chevy fixed yoke.
  #119
Old 07-09-2014 | 01:52 AM
blaz's Avatar
Attached Thumbnails Blaz's 05 blazer-20140701_161755_zpsclrapm1g.jpg   Blaz's 05 blazer-20140707_231956_zpsan7xr31v.jpg   Blaz's 05 blazer-20140708_144537_zpsfsxupevq.jpg   Blaz's 05 blazer-20140707_201015_zpsxamdtktk.jpg   Blaz's 05 blazer-20140707_203958_zpscvsox6da.jpg
  #120
Old 07-09-2014 | 07:10 AM
rexmburns's Avatar
Super Moderator
This is exciting!
Quick Reply: Blaz's 05 blazer
