Blaz's 05 blazer
Old Oct 22, 2014 | 08:44 AM
  #191
rexmburns's Avatar
Super Moderator
Man seeing your build thread and the tools in the pics makes me miss being a machinist and having access to a CNC, lathe and mill not to mention all the other fun tools that come along with a machine shop! Awesome work and awesome fab skills man keep up the good work!
Old Oct 29, 2014 | 12:05 PM
  #192
El_Beautor's Avatar
Very nice work Blaz, and your assistant Jamaroon does good work too! Your rig looks awesome.
Old Oct 30, 2014 | 09:28 AM
  #193
Jamaroon's Avatar
lol thanks EB
Old Oct 30, 2014 | 05:41 PM
  #194
blaz's Avatar
blaz is on a distinguished road
Thanks. He does ok for what I pay him.....LoL.
Updates will be coming soon.
Old Nov 1, 2014 | 10:31 PM
  #195
blaz's Avatar
When I flexed the blazer out last time I realized that the rear springs were starting to move toward a negative arc. Rear bump stops were needed. My solution was to simply put a plate on top of the U bolts and use the factory stop. The U bolts have a nut holding the axle in place and a second nut holding the plate on.
Front sway bar was also a concern. I tried the stock one but it would hit the front factory crossmember.
I was able to get a swaybar from a 87 xj and I fabbed up some mounts because it is wider and the straps were rusting though.
Disconnected position.
Connected position.
Attached Thumbnails Blaz's 05 blazer-20141019_155007_zps5k6ddflf.jpg   Blaz's 05 blazer-20141010_143350_zpse5yepgi4.jpg   Blaz's 05 blazer-20141014_194236_zpsx9g3zk8q.jpg   Blaz's 05 blazer-20141026_170016_zpstewq4fhf.jpg   Blaz's 05 blazer-20141014_195506_zpsrftuk1ly.jpg
Blaz's 05 blazer-20141014_195524_zpsmbgfs4qp.jpg   Blaz's 05 blazer-20141014_194323_zps27vrwugr.jpg   Blaz's 05 blazer-20141014_195646_zps1h5jsd2i.jpg
Old Nov 1, 2014 | 10:40 PM
  #196
blaz's Avatar
Swaybar links were next as well as an axle mount.
Picked up some 1" cold rolled mild steel and turned and threaded it for the stock s10 bushings and a wing nut.
The other end of the 1" stock I drilled to fit the T bar cossmember mounts. Then welded them in.
Yes I weld like I drink my tea, with my pinky up. LOL.
Roughed out a plate for the axle mount.
Prettied up the plate a bit with a radius and no sharp points.
Attached Thumbnails Blaz's 05 blazer-image-20_zpsih6cn5rn.jpeg   Blaz's 05 blazer-20141024_205041_zpslwnnykwb.jpg   Blaz's 05 blazer-image-22_zpsbqwmvypt.jpeg   Blaz's 05 blazer-image-27_zpsxrrbge5l.jpeg   Blaz's 05 blazer-image-26_zpsgcbjyujd.jpeg
Blaz's 05 blazer-20141026_190908_zpskki4yc6k.jpg   Blaz's 05 blazer-image-28_zpsucyupeui.jpeg
Old Nov 1, 2014 | 10:45 PM
  #197
blaz's Avatar
Ran out of TIG gas so I stick welded the brackets to the axle. Not my best welds, but still strong. The flux was still on it in the pic.
The other side.
That last pic may also lead you to what is coming next..............
Attached Thumbnails Blaz's 05 blazer-image-23_zpshxko79mm.jpeg   Blaz's 05 blazer-image-24_zpsx8razvin.jpeg
Old Nov 1, 2014 | 10:52 PM
  #198
blaz's Avatar
Yup, wheels and tires. I was able to find 4 ZQ8 rims locally for $350.
Loaded the new rubber in the back.
WoW!
Finally got them mounted on the blazer.
Attached Thumbnails Blaz's 05 blazer-20141025_165458_zpsg7skntna.jpg   Blaz's 05 blazer-20141025_165005_zpsqndferwe.jpg   Blaz's 05 blazer-20141029_211118_zpsipxbnen9.jpg   Blaz's 05 blazer-20141029_214501_zpsyavpfsej.jpg   Blaz's 05 blazer-20141030_202605_zpshgslq4cw.jpg
Blaz's 05 blazer-20141101_161434_zpsstsngcpt.jpg   Blaz's 05 blazer-20141101_161456_zps2oxj5afk.jpg   Blaz's 05 blazer-20141101_161517_zpsucikvx1f.jpg   Blaz's 05 blazer-20141101_161540_zpsgzxwfphf.jpg   Blaz's 05 blazer-20141101_161615_zpssm11akwa.jpg
Old Nov 2, 2014 | 09:25 AM
  #199
rexmburns's Avatar
Super Moderator
Damn that looks perfect!!!
Old Nov 2, 2014 | 09:41 PM
  #200
blaz's Avatar
Perfect other than more front fender trimming to do.
