crossmember mount bushing in polyurathane.??!!????
Old Oct 27, 2019 | 12:31 PM
hurleyii's Avatar
hurleyii is on a distinguished road
Default crossmember mount bushing in polyurathane.??!!????
Well guys in for penny in for a pound I guess! Anybody have a part number for the torsion bar mount in polyurethane
or a end link kit they have used.
Things ordered already . RO 2.5 lift kit ordered, gas tank ,fuel pump, evap thingy, polyerathane body mounts custom made 1/2 body spacers, polyurethane leaf spring kit ( took one for s10 and one for full-size do to spring code and 1/2 ton bolts for front mount.) Tcase rebuild kit, rebuilt engine, ZR2 rear axle, front diff, full Zr2 donor, rebuilt engine, JBA headers, junkyard interior, and body repair crap. New steering gear box and all new suspension everything. Did I miss anything guys? Anybody want to donate a rust free truck. Lol
Plans are as follows. Custom size dual exhaust as large as I can fit coming off engine but not larger then whatever the full-size truck short headers collector would be on same year of 4.3. Repair rusted out sections by cutting cancer out. Undercoat body and frame install as much of ZR2 suspension as possible. Hopefully when I’m done since truck was free it’ll be worth at least half of what I’ve financially invested. But it’s good practice for my race car which is the point of the body work.
Old Oct 27, 2019 | 01:29 PM
Ex-Calif's Avatar
Ex-Calif is on a distinguished road
Dang... that’s ambitious. Long road ahead. Will be watching.
Old Oct 27, 2019 | 10:09 PM
hurleyii's Avatar
Update .... ZR2 front clip off, fenders will do including passenger inside fender. Driver side gonna order a new one I think....
Also it’s Radiator core support was in pretty good shape. Nothing a wire wheel and sandblaster at grounding points won’t fix.
Got the Driver-side lower control arm off... FYI clean hands and hammer off before beating the sh*t out of control arm to get off the dam torsion bar. Slipped one to many times and had to use die finder to cut big thing torsion bar goes in. Tomorrow night will take 6” grinder and cut the torsion bar mounting bracket and slice the key on 2 sides to avoid hitting it with a torch.
Passenger side took 6 hits with hammer and the torsion bar come flying out of the key. Took sawzaw put 2 notch in lower control arm close together in a v pattern. Drove a cold chisel in notch smacked the control arm a few times and out came the torsion bar.
In case I didn’t note I got the blazer keys and torsion bars out last night.
Toby Hanson
Sep 11, 2020 12:44 PM
sputnik
Dec 15, 2012 11:42 PM
c0a8l0v6i8n9
Sep 3, 2008 07:51 PM
blazerboy30
May 27, 2008 10:22 PM
Blazin_Jason
Suspension Tech
Apr 15, 2007 07:43 PM
