Envoy HID Headllight Modification (98-01)
Old Jun 13, 2010 | 06:30 AM
mr.vls's Avatar
Default Envoy HID Headllight Modification (98-01)
If you have factory HID headlights on your Envoy/Bravada and the bulb and ballast go out you find out real quick that the only available replacements are from GM and you have to buy a new ballast/HID Bulb because of design change. The cost from GM is over $1,000 dollars for the set. If you want to keep your factory HID system I have a mucn lower cost alternative and still be OEM equipment. I have purchased factory Bulb/Ballast to keep my GMC Diamond Edition factory HID lights operational but will never again. Below is what I purchased (Mostly From Ebay)
1. Philips D1S Bulb Xenstart ($50.00 ea) Ebay. 2 ea
2. Philips Xenstart ballast (Cadilac XLR) Same Ballast as what you get from GM. (Price Varies) 2 ea
3. Pair of D1S Bulb Holders. ($30.00)
4. Pair of D1S Cables 49CM (SUV Lights.com) $75.00 for a pair includes shipping.
Note: The only difference with the ballast assy. from GM/Ebay is that GM provides an adapter plate that will mount the ballast using the same mountin screw locations as the original and provides a short extension for the wiring harness. Part number/Spec for the ballast is the same.
The key is mounting the D1S bulb holders to the back of the headlight assemblies without damaging or modifing the headllight assy. I made a right left adapter from piece of sheet metal. The ballast can be mounted in the same location as the original. PIC's to follow later today.
Old Jun 13, 2010 | 12:31 PM
oktain's Avatar
Nice job on this, hopefully people will find it and save some do-reh-mi
Old Jun 13, 2010 | 02:46 PM
MTopper's Avatar
any pictures of it? i know it doesn't help me but pictures are always fun to see with everything. great idea
Old Jun 13, 2010 | 04:21 PM
mr.vls's Avatar
Attached are pics of my headlight modification. Using a replacement from ebay you would have to splice in the power connector and mount it without having the mounting plate. But buying a ballast on ebay for $50.00 vice $600.00 I can live without a mounting plate or plug adapter.
Attached Thumbnails Envoy HID Headllight Modification (98-01)-mvc-494s.jpg   Envoy HID Headllight Modification (98-01)-mvc-496s.jpg   Envoy HID Headllight Modification (98-01)-mvc-497s.jpg   Envoy HID Headllight Modification (98-01)-mvc-498s.jpg   Envoy HID Headllight Modification (98-01)-mvc-499s.jpg
Old Jun 13, 2010 | 04:27 PM
mr.vls's Avatar
Below are pics of the GM OEM replacement bulb, ballast with mounting plate and adapter plug. Using a ballast of off ebay you would not get the mounting plate or the plug adapter. But the ballasts are exactly the same ballast. This bulb and ballast is over $1000.00 from GM. You can get buy with around $900.00 if you buy the complete headlight assembly that includes bulb and ballast. I can not figure why it is less expensive to buy the complete assy then just the replacement bulb/ballasst.
Attached Thumbnails Envoy HID Headllight Modification (98-01)-mvc-500s.jpg   Envoy HID Headllight Modification (98-01)-mvc-501s.jpg
mr.vls
Oct 9, 2009 06:29 PM
paulf707
Jun 30, 2008 08:25 PM
Newbeme
Feb 8, 2008 10:42 PM
jjimmy
Dec 9, 2007 10:06 AM
prototype80
Jul 13, 2006 08:19 PM
