German 98 Blazer build
#271
I believe the speed sensor is on the tail shaft of the transfer case.
you can kind of see it on this pick.
![](https://lh4.ggpht.com/_SUEvWXDjWPc/Sqk0lPh67gI/AAAAAAAACes/KZRUsHZQSwk/s800/BUGluwB2kKGrHgoH-EMEjlLluimHBKL0e23-VQ_3.JPG)
![](http://www.gmthq.com/images/transfercase/np233c/replace-seals/tranfer_case_01.jpg)
#272
Thanks for the pics.
I`ll check tomorrow if it`s the Vss. If it`s bad, then my obd reader shouldn`t get a speed signal. If it get`s a signal then it`s the speedo itself...
I`ve read that the vss works with various resistances. Do if a wire is broken the speedo reads unlimited resistance and is at full speed. Maybe this could be the problem too?
#273
No idea. But those vss are $5 here used. No idea what they are new.
#274
This was an easy fix. I just disconnected the battery over night and this morning the speedo just worked normal...
#275
Made my own lift mate today. Started this morning with those parts:
![](http://www.abload.de/img/img_8031wqzn.jpg)
A little grinder action:
![](http://www.abload.de/img/img_8032qsf2.jpg)
All welded up. I couldn`t get any nice welds today, not sure why...
![](http://www.abload.de/img/img_80343o4d.jpg)
Test:
![](http://www.abload.de/img/img_8036opat.jpg)
![](http://www.abload.de/img/img_8037kq6s.jpg)
After this test i realized that i forgot the bolt that holds the second strap, so it actually hang on only one strap...
The paint is drying right now, more pics when it`s finished...
Test:
#276
looks good,if i ever get stuck to where i need one of those jacks ima gonna use my winch,you sure came along ways on this truck,hows that intake gasket holding up?
#277
Hi,
there are lot`s of situations where a winch is absolutely useless. The I use my hilift or the air jack. Sand ladders and a pull pal still missing...
The intake gasket is holding up fine...
#278
Today i added a sticker of our german board:
![](http://www.abload.de/img/img_8041wpq5.jpg)
Then I started with a tree removal in our backyard. This tree had to go:
![](http://www.abload.de/img/img_8045xs1b.jpg)
Cut down:
![](http://www.abload.de/img/img_8048cprg.jpg)
My car with all the limbs inside and on the roof rack:
![](http://www.abload.de/img/img_8050so6g.jpg)
![](http://www.abload.de/img/img_80515olg.jpg)
Then i hooked it on my winch and started pulling:
![](http://www.abload.de/img/img_8056cqpc.jpg)
Result:
![](http://www.abload.de/img/img_8060apvm.jpg)
![](http://www.abload.de/img/img_8059mp6w.jpg)
Was a fun day...
Cut down:
Result:
Was a fun day...
#279
nice!!! I want a winch so bad. I like the mod to the high lift too
#280
The finger at the completion of your projects are becoming like a sig.
Always makes me laugh.
