GMC Jimmy 2.5" Lift 31x10.5 etc
#131
Don't plan on doing any mods this summer. Only lower ball joints, tie rods maybe, differential lube, pinion seal rear axle transfer case, rear rotors, trim inner fenders more, after this winter have to sand and paint some rust probably. Going to try that POR15 Anti Rust this time around. Get some heat resistant spray for exhaust. Then next year I plan to either switch to 6" suspension or just add 2" body lift then paint any frame showing black. Then get 32x10.5" may try a more aggresive tread not sure. I like my BFG.
#132
Your truck looks good as is and has swayed me heavily towards buying the RC kit and running 31s.
#133
#134
#135
#136
Trailer Wire
Thanks
#137
#138
Figured Id share some snow photos.. Heres from a month ago..
AND then here are 2 from this week! almost end of April. arg.
PS: I tore the unplowed roads right up. Love this truck.
#139
i want to put a 2.5 inch lift on my 1999 jimmy. would you be able to tell me what the best way to do that would be? I know i can go to roughcountry and buy one for about 400 dollars. and i know i could also crank the t-bars. just looking for a little input thanks.
#140
If you go with Rough Countrys kit it will save your suspension. Gives you all the brackets you need to make your CVs not get worn. I suggest go with their kit forsure. I love mine. No issues yet.
